I use a shared computer, so I need to make it user friendly for my-less-than-computer-knowledgable friend
currently have Ubuntu 12.10 installed
I would like to change the GRUB menu so that Windows 7 is at the top of the list (thus allowing the automatic timeout to automatically select it on startup) and Ubuntu down below
I've already used the information used at { How do I change the GRUB boot order? } and that didn't work.
You can change the default boot by editing the grub config:
sudo nano /etc/default/grub
Change the line *GRUB_DEFAULT=0* so that it reflects which grub boot line is the one you want to boot off: eg *GRUB_DEFAULT=2* etc.
You will then need to update the grub boot menu so that this change takes effect:
sudo update-grub
Having to select the correct OS from a men is hardly unfriendly, but if you really have to...
fabricator4
  • 8,471
  • 37
  • 39
Edit /etc/default/grub and change GRUB_DEFAULT value from 0 to the number of your friends Windows 7 in grub boot menu.
Then Run sudo update-grub2
