I have a Brother MFC-7420, which also works as a scanner. I have attached this machine to a computer running Ubuntu 12.04 LTS 64bit via USB.
I installed the following package:
brscan2-0.2.4-0.i386.deb
Now when I start xsane, the device is detected. However, when I try to scan or run a preview scan, I get the message Could not start scanner: Invalid Argument. The same problem exists if I run xsane as root, so I don't think it's a privilege problem.
There's no output on the console while running xsane (see screenshot below). The dialog box showing the error appeared just after pressing the "scan" button in xsane. Sreenshot showing the error
What can I do to get this scanner running?
Bob
  • 166
I had the same problem and fixed it by editing /lib/udev/rules.d/40-libsane.rules.
I uncommented the line:
ENV{DEVTYPE}=="usb_device", MODE="0664", OWNER="root", GROUP="root"
Then edited it to be:
ENV{DEVTYPE}=="usb_device", MODE="0664", OWNER="root", GROUP="saned"
After that I added my user to the saned group. It all works now.
The problem is that it wants to run as root till you do this.
Eric Carvalho
  • 55,453
If none of the above work, what worked for me was to go to the brother site. The issue is that - at least with Brscan2 x64 - that the drivers are installed to the wrong directory. go to Brother sacanner Faq if you look @ the section: that says
I'm using Ubuntu 11.10 or higher. I cannot scan from my Brother Machine.
the instructions say to copy some files - that was what ultimately solved it for me. I expected that when I installed the Brother linux drivers, that was it. But no, the drivers installed to directories that my version of ubuntu (linux mint Nadia Xfce x64) doesn't use. So copying those files over immediately solved it.
