150
I've become very accustomed to managing service startups on Redhat/RHEL platforms using chkconfig though that doesn't appear to be the Debian/Ubuntu way - How do I update runlevel information for system services on Ubuntu?
Ultimately looking for the equivalents of:
chkconfig --add <service>
chkconfig --level 345 <service> on
chkconfig --del <service>
Marco Ceppi
  • 48,827
5 Answers5
129
The equivalent to chkconfig is update-rc.d
The equivalents you seek are
update-rc.d <service> defaults
update-rc.d <service> start 20 3 4 5
update-rc.d -f <service>  remove
See this useful page for more information or check out man update-rc.d
Zanna
  • 72,312
55
Best alternative IMHO is sysv-rc-conf To install just need to run the command:
sudo apt-get install sysv-rc-conf
Once installed run the command:
sudo sysv-rc-conf
You can check or uncheck the options to start a service on any level of execution and may even stop or start the services from this console. It is an indispensable tool to enable or disable applications on an permanently way to boot your ubuntu If you need a quick change, then you can use the CLI interface:
For example to stop ssh at levels 3 and 5 of execution:
sysv-rc-conf-off level 35 ssh
Atd to start in runlevels 2,3,4 and 5:
sysv-rc-conf on atd
If you want to know more:
man sysv-rc-conf
Marco Ceppi
  • 48,827
jokerulez
  • 551
10
Try this:
apt-get install chkconfig
This works, at least of as Ubuntu 12.04 release.
Eliah Kagan
  • 119,640
10
Right now, there is no equivalent on a stable release for doing things with Upstart scripts. Jacob Peddicord wrote jobservice (backend daemon) and jobs-admin (GTK+ GUI that talks to it) for his Google Summer of Code project. Lucid packages are in his PPA. They also exist in Universe in Maverick. There is no command line front-end for jobservice yet, just jobs-admin.
maco
  • 16,132
Lets walk from ZERO to Goal - how to do it with step by step.
Step 1: lets write a hello world
cat >> /var/tmp/python/server.py <<\EOF
#/usr/bin/python
import time
while True:
  print "hello> YES Bello"
  time.sleep(30)
EOF
Step 2: lets make our hello world application server.py automated
cat >> /var/tmp/myserver.sh <<\EOF
#!/bin/sh
script='/var/tmp/python/server.py'
export DISPLAY=:0.0 && /usr/bin/python $script &
EOF
chmod +x /var/tmp/myserver.sh
cat >> /etc/init.d/myserver <<\EOF
#! /bin/sh
PATH=/bin:/usr/bin:/sbin:/usr/sbin
DAEMON=/var/tmp/myserver.sh
PIDFILE=/var/run/myserver.pid
test -x $DAEMON || exit 0
. /lib/lsb/init-functions
case "$1" in
  start)
     log_daemon_msg "Starting feedparser"
     start_daemon -p $PIDFILE $DAEMON
     log_end_msg $?
  stop)
     log_daemon_msg "Stopping feedparser"
     killproc -p $PIDFILE $DAEMON
     PID=`ps x |grep server.py | head -1 | awk '{print $1}'`
     kill -9 $PID
     log_end_msg $?
  force-reload|restart)
     $0 stop
     $0 start
  status)
     status_of_proc -p $PIDFILE $DAEMON atd && exit 0 || exit $?
   echo "Usage: /etc/init.d/atd {start|stop|restart|force-reload|status}"
   exit 1
esac
exit 0
EOF
chmod +x /etc/init.d/myserver
chmod -R 777 /etc/init.d/myserver
Step 3:
$ update-rc.d myserver defaults
update-rc.d: warning: /etc/init.d/myserver missing LSB information
update-rc.d: see <http://wiki.debian.org/LSBInitScripts>
 Adding system startup for /etc/init.d/myserver ...
   /etc/rc0.d/K20myserver -> ../init.d/myserver
   /etc/rc1.d/K20myserver -> ../init.d/myserver
   /etc/rc6.d/K20myserver -> ../init.d/myserver
   /etc/rc2.d/S20myserver -> ../init.d/myserver
   /etc/rc3.d/S20myserver -> ../init.d/myserver
   /etc/rc4.d/S20myserver -> ../init.d/myserver
   /etc/rc5.d/S20myserver -> ../init.d/myserver
  • So in step 3, the system on boot, will automatically execute the server.py as daemon and make it easy to automate
Hope it helped.
