Tumblr uses alt+click to reblog, but Compiz uses alt+drag to move windows. This is convenient for some, but I have literally never used Compiz's alt+drag and would like to disable it. How can I get rid of the alt+click+drag function without disabling alt completely?
This is different from this question because I would like to disable this functionality, NOT move it to the Super key.
Zanna
  • 72,312
Install the Compiz settings manager if you don't have it already. In terminal:
sudo apt-get install compizconfig-settings-manager
Now find and open the settings manager. Find the Move Window plug-in. (You don't want to disable the plug-in; if you do that you won't be able to move windows at all.)
Just change the first setting, Initiate Window Move. It can be change it from Alt+Button 1 to Super+Button 1, but you stated that is not what you want, so just click on Alt+Button 1 and uncheck Enabled.
Zanna
  • 72,312
leighton
  • 166
Some more information: I tried to disable the Alt+Button 1, and all my window bars gone. This is not expected, I consider it a bug. And when I reboot my Ubuntu, the setting is recovered.
In my case, it cannot be disabled, but changing it into Super+Button 1 works fine for me.
ice1000
  • 101
