I followed every step indicated at How To Harmonize Your Dual-Boot Setup for Windows and Ubuntu and that worked perfectly, only I couldn't send items on NTFS partition to trash.
If you have the same problem, just add the options "uid=1000" and "gid=1000" to fstab, on the line that concerns the ntfs partition.
Mine looks like that:
# storage mount
UUID=3F4648C2710CF3A1 /media/storage/ ntfs-3g auto,user,utf8,uid=1000,gid=1000,rw 0 0
So the full steps from scratch are (as given by YatriTrivedi from howtogeek.com and Manu Järvinen from his blog)
1. Set up a new GPT partition table in your clean drive (from a live usb ubuntu distro, using gparted). Plan your partition scheme in a similar way:
- An EFI System Partition (ESP) of at least 100MB, this will be the brains of the system booting
- Your Windows partition (NTFS)
- Your Linux partition (Ext4)
- A large partition (or second hard drive) to store your files (NTFS)
- A small swap partition (SWAP)
Don't forget to label your partitions for later convenience.
From my personal experience, if you plan on playing games or using specialized software on Windows (Adobe Suite, ARCGIS, Autodesk and the like), plan on having at least 100GB on your Windows partition. With 150GB and above you should be fine. Ubuntu softwares are much less demanding on storage capacity, so you can easily set up a 50 to 75GB Linux partition depending on your needs.
2. sudo apt install ntfs-3g to let linux handle ntfs file system, which is the only that both OSs can read.
3. sudo mkdir /media/storage or any other place you'd like your partition to appear. If you don't know where, just copy/paste that line.
4. sudo cp /etc/fstab /etc/fstab.backup to backup your fstab file, which contains information about what your system should do with your disk partitions. Editing fstab will tell linux to mount that partition properly at each startup, so making a backup is always useful in case things don't work out well. sudo cp /etc/fstab.backup /etc/fstab to restore the backup if needed.
5. You now have to find the UUID of your partition, it's an unique identifier that acts as a serial number: sudo blkid. Enter your password, and next find the line that corresponds to your storage partition.
/dev/sda1: UUID=”23A87DBF64597DF1″ TYPE=”ntfs”
/dev/sda2: UUID=”2479675e-2898-48c7-849f-132bb6d8f150″ TYPE=”ext4″
/dev/sda5: UUID=”66E53AEC54455DB2″ LABEL=”storage” TYPE=”ntfs”
/dev/sda6: UUID=”05bbf608-87fa-4473-9774-cf4b2602d8d6″ TYPE=”swap”
This is where your labeling during the initial formatting gets useful. Copy the UUID.
6. gksudo gedit /etc/fstab this will open fstab for editting. Add the following line at the very bottom of fstab, and paste your UUID instead of mine: # storage mount
Setting uid=1000 and gid=1000 somehow allows you to send your items to trash from Linux. Don't touch anything else from fstab and make sure your UUID is correct.
7. Save and reboot (important).
And voilà, now you should be able to notice that you have a "storage" under the places menu. Next, configure your subfolders within Linux and Windows to have your documents etc, stored in that partition!
