I have an ubuntu 12.04 setup with two HDD that is setup in a software raid 1. Now I need to add two additional SSD drives for separate storage of some database files. They need to be setup in their own separate raid 1 array. Unfortunately I have no idea where and how to start? So from the beginning after having plugged the two drives in, and booted the server - then what?
Okay i got it:
1) First list all drives: sudo lshw -c storage -c disk
and note down the drives that needs to be put into a new raid array (in my case /dev/sda and /dev/sdb)
1.1) If you need to find out what drives are already in a raid this can be done with sudo cat /etc/mdadm/mdadm.conf details about which drives they cover can be inspected with sudo mdadm --query --detail /dev/md0 where /dev/md0 is the array you want to inspect.
2) Now use fdisk to format the drives and create partitions for each drive: sudo fdisk /dev/sda this is done for each drive (and they should of cause be setup equally)
- If the disk is not "clean" then press
dand follow instructions to delete the current partitions (note all data will be lost on that disk!) - Then press
nto create a new partition. - Press
pfor primary and1for one partition, and use the defaults (pressingreturn). - Press
tfor type and set the partition type to fd (linux raid autodetect). - press
wfor writing your changes and exit.
3) Create the RAID array: sudo mdadm --create /dev/md3 --chunk=128 --level=1 --raid-devices=2 /dev/sda1 /dev/sdb1
4) Format the array: sudo mkfs -t ext4 /dev/md3
5) Lookup the infor for the new array using method in step 1.1 and edit sudo nano /etc/mdadm/mdadm.conf accordingly with the following line for your new array ARRAY /dev/md/3 metadata=1.2 UUID=f368e29e:b79c72bd:631ce90f:e3370f90 name=master-db:3
6) Create a directory (mount dir) for the new drive sudo mkdir /new_device
7) Mount to fstab by editing sudo nano /etc/fstab with /dev/md3 /new_device auto defaults 0 0
8) Run sudo mount -a
Check that everything runs with: sudo cat /proc/mdstat
Some helpfull links: https://help.ubuntu.com/community/Installation/SoftwareRAID http://superuser.com/questions/230497/how-can-i-add-a-raid-1-array-in-ubuntu-10-04 Which hard disk drive is which?
- 1,039
- 3
- 11
- 16
