I have installed 12.04LTS server edition, no GUI. At some interval, maybe 5 minutes the screen will blank and I have to hit a key to show the screen again.
I have spent hours surfing but cannot find how to change the interval. My question is where do I modify the timeout parameter (through terminal) and where should I have looked for the answer?
There is plenty of advice out there for the GUI version but none I could find for the CLI version
VedVals
  • 3,651
wally
Hope this help you Link
The first answer will help you solve your problems.
Solution
  • Open /etc/default/grub in your favorite editor; you will need to use sudo (for vi, nano, etc.) or gksudo (for gedit, etc.).
  • Then add consoleblank=0 to the GRUB_CMDLINE_LINUX_DEFAULT=, parameter.
  • e.g. yours may say:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash consoleblank=0"
Then run sudo update-grub, and reboot.
Diego
  • 611
From This link
setterm -powersave off -blank 0
check out man setterm for more info.
Be super careful with this, you can bork your monitor.....
coteyr
  • 18,724
