59
How to disable blank screensaver on Ubuntu Server?
There's no desktop or X, only console (command-line interface).
ish
  • 141,990
Alex
  • 781
The easiest way is to add the parameter consoleblank=0 to your kernel command-line at boot-time.
  • Open /etc/default/grub in your favorite editor; you will need to use sudo (for vi, nano, etc.) or gksudo (for gedit, etc.).
  • Then add consoleblank=0 to the GRUB_CMDLINE_LINUX_DEFAULT=, parameter.
  • e.g. yours may say:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash consoleblank=0"
Then run sudo update-grub, and reboot.
ish
  • 141,990
23
Type setterm -blank 0 on any shell to disable blanking out of tty consoles.
0 disables blanking, any value greater than 0 is the time in minutes. Default is 10.
To permanently enable this you can add this line to your ~/.bashrc config.
A more detailled explaination can be found in this answer at superuser.
q9f
  • 1,261
  • 18
  • 30
Same situation, the other suggestions seemed a roundabout solution. Came across the GNU tool setvesablank on/off using apropos. It seems the best fit, trying it out to see if it fits the need.
This will "overwrite" whatever is in your current config for "GRUB_CMDLINE_LINUX_DEFAULT=", mine was default, so I just use the following One Liner.
sudo sed -i 's/\(^GRUB_CMDLINE_LINUX_DEFAULT=\).*/\GRUB_CMDLINE_LINUX_DEFAULT="consoleblank=0"/' /etc/default/grub && sudo update-grub2
FreeSoftwareServers
  • 1,129
  • 14
  • 32
