I installed Ubuntu with several Desktop Environments, including Unity, KDE and LXDE.
I am struggling to change the background tooltip color which is black and causes displaying problems in Eclipse.
I managed to do this in Unity as explained here: How to change tooltip background color in Unity?
I was unable to do this in LXDE. However when I changed the tooltip background color from KDE GUI settings (System Settings -> Application Appearance -> Colors), the change was also reflected in LXDE, so I assume there must be a configuration file from which all desktop environments read this information.
Where are theme settings stored?
KDE
The KDE is saving the own settings to the /home/[user]/.kde/...
The color settings are saved to the /1/:
Colors
The colors file follows the standard KDE colorscheme file format and allows a theme to define what colors work best with its theme elements...
Saved at /home/[user]/.kde/share/apps/color-schemes/[unique name].colors ...
If you are editing the "current" color scheme then the settings are saved to the kdeglobals file - /home/[user]/.kde/share/config/kdeglobals.
Links
  1. http://techbase.kde.org/Development/Tutorials/Plasma/ThemeDetails
user26687
  • 15,174
What you are looking for is GTK theme settings which is used by GTK applications in KDE and other desktop environments (Unity, LXDE, ..):
~/.gtkrc-2.0
Source: Is there a way to stop KDE from overwriting my other WM settings?
user.dz
  • 49,176
