After upgrading from 12.04 to 12.10 last night, I received several error messages. I try to send reports for the Ubuntu teams, and after the upgrading finished, I realise it's a complete failure. When I boot the computer, I get to the desktop with the icone but then I cannot do much as it is all frozen. I start to freeze, nothing can be done for 3-4 minutes, then all icones and bars dissappear and reappear, it seems like it unfreezes but refreezes instantly. However I can use the terminal, so does anyone have an idea how to reinstall or fix this through the terminal or whatever?
Asked
Active
Viewed 259 times
You could try doing a fresh install (assuming you don't have important files on the drive) as opposed to an upgrade. In some cases, upgrades can create problems:
http://ubuntuforums.org/showthread.php?t=1973093
http://ubuntuper.wordpress.com/2010/09/17/fresh-install-vs-upgrade-benefits-and-negatives-with-both/
If you can use the terminal without problems, you could try getting updates.
Matt
- 51
