Possible Duplicate:
How to install tor?
I would like to install the Tor, but I'm having some problems. I know that someone will say "This question is a exactly duplication of How to install tor?", but it's not, because the another question can not be applied to Ubuntu 12.10 as the deb command is not available anymore.
I did a research and even at the Tor's Official Website the available resource can not be applied to Ubuntu 12.10.
I tried to use the deb command (as the above question says: deb http://deb.torproject.org/torproject.org <DISTRIBUTION> main) and the Terminal says deb: command not found and when I try to install it says E: Unable to locate package deb.
I've also tried to use the ppa: ubun-tor, but it's not compatible with Quantal Quetzal, because it's too old.
I've also tried to use sudo apt-get install tor, but browser icon don't shows up after installation and if you try to use the command tor in the Terminal I get the following error message:
Nov 26 10:59:25.731 [notice] Tor v0.2.3.22-rc (git-4a0c70a817797420) running on Linux.
Nov 26 10:59:25.731 [notice] Tor can't help you if you use it wrong! Learn how to be safe at https://www.torproject.org/download/download#warning
Nov 26 10:59:25.731 [notice] Read configuration file "/etc/tor/torrc".
Nov 26 10:59:25.737 [notice] Initialized libevent version 2.0.19-stable using method epoll (with changelist). Good.
Nov 26 10:59:25.737 [notice] Opening Socks listener on 127.0.0.1:9050
Nov 26 10:59:25.737 [warn] Could not bind to 127.0.0.1:9050: Address already in use. Is Tor already running?
Nov 26 10:59:25.737 [warn] Failed to parse/validate config: Failed to bind one of the listener ports.
Nov 26 10:59:25.737 [err] Reading config failed--see warnings above.
Thanks in advance.
Zignd
  • 10,982
