79
Since I can't seem to open the Additional Drivers program? And how do I know what driver I need to install?
Jorge Castro
  • 73,717
TheXed
  • 27,638
5 Answers5
126
For 14.04 and above
sudo ubuntu-drivers list
Will show all the driver packages which apply to your current system. You can then
sudo ubuntu-drivers install      # on modern Ubuntu, or
sudo ubuntu-drivers autoinstall  # on older versions.
to install all the packages you need, or you can do:
sudo ubuntu-drivers devices
to show you which devices need drivers, and their corresponding package names.
Oli
  • 299,380
33
For 12.04 and below
The additional drivers program has a command line interface, jockey-text:
Use
jockey-text --list
to get a list of available drivers and their status, then use
# the init lines are required only for graphics drivers
sudo init 1
jockey-text --enable=DRIVER
sudo init 2
where DRIVER is the one you got from the list. For example:
jockey-text --enable=firmware:b43
To install the Broadcom B43 wireless driver.
For your graphics card, you will get a choice of the proprietary driver from the manufacturer and a free alternative. You have to either restart the display server (log out and back in) or restart the system entirely (recommended).
Jorge Castro
  • 73,717
For 12.04 and below
The internal name of the "additional drivers" program is jockey-gtk. There's a console version with the same functionality called jockey-text in the eponymous package. It should be installed by default.
You should be able to use
jockey-text -l
to list the available drivers and something like
jockey-text -e xorg:nvidia-185
to install one of the options listed. You should select the most appropriate driver listed.
Jorge Castro
  • 73,717
loevborg
  • 7,414
If you have a Nvidia graphics card:
You need to run
sudo apt-get install nvidia-current
sudo nvidia-xconfig
Then reboot:
sudo reboot
and you should have a working system.
RolandiXor
  • 51,797
After install nvidia driver you can regenerate xorg config for your nvidia adapter:
sudo nvidia-xconfig
Also, you can download the driver from www.nvidia.com and install it manually:
sudo sh ./downloads/NVIDIA-Linux-x86-xxx.xx.xx.run
DsXack
  • 59
