Here is my issue: Ubuntu starts perfectly, but when I get to the login screen and try to log in, I get a black screen and a few seconds later I'm back to the login screen.
I believe the problem comes from the graphic card driver since I had just switched from the alternative driver to the proprietary one before I got the issue. (I used the Software and Updates app to do so.)
I have an Asus with i7 and a dual-boot with Windows and Ubuntu 18.04 (Grub starts fine). My graphic card is Nvidia Geforce 920M.
Thank you!
PS: I'm a beginner Ubuntu user, don't hesitate to ask if I forgot essential info.
EDIT: following @JoshuaBesneatte answer, I did the following :
  1. sudo apt-get purge nvidia and reboot. I can now log in, but the window is now "zoomed in". (Weirdly, the "zoomed in" problem wasn't there the first time I did step 1).
  2. I added the graphics drivers repository: sudo add-apt-repository ppa:graphics-drivers. Checking Software and Updates a bit later (not sure the change comes from this command), I now have 4 possibilities : 3 Nvidia drivers (390, 400 and 415) and Nouveau display driver (I only had one Nvidia possibility before).
  3. I Updated (sudo apt update) :
    leo@leo:~$ sudo apt-get update
    [sudo] password for leo:
    Hit:1 http://uk-mirrors.evowise.com/ubuntu bionic InRelease
    Hit:2 http://archive.canonical.com/ubuntu bionic InRelease
    Hit:3 http://uk-mirrors.evowise.com/ubuntu bionic-backports InRelease
    Hit:4 http://uk-mirrors.evowise.com/ubuntu bionic-security InRelease
    Hit:5 http://ppa.launchpad.net/bluetooth/bluez/ubuntu bionic InRelease
    Hit:6 http://uk-mirrors.evowise.com/ubuntu bionic-updates InRelease
    Hit:7 http://ppa.launchpad.net/daniruiz/flat-remix/ubuntu bionic InRelease
    Hit:8 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic InRelease
    Hit:9 http://ppa.launchpad.net/linrunner/tlp/ubuntu bionic InRelease
    Hit:10 http://ppa.launchpad.net/nathan-renniewaldock/flux/ubuntu bionic InRelease
    Reading package lists... Done
  4. I tried installing Nvidia drivers :
    • nvidia-current didn't work (sudo apt install nvidia-current) :
      leo@leo:~$ sudo apt install nvidia-current
      Building dependency tree
      nvidia-current : Depends: nvidia-304 but it is not going to be installed
    • After doing step 1 again, I tried installing 390 (sudo apt install nvidia-driver-390). It seemed to work, and the sudo nvidia-xconfig gave the following result :
      sudo nvidia-xconfig
      Using X configuration file: "/etc/X11/xorg.conf".
      Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
      New X configuration file written to '/etc/X11/xorg.conf'
    But after rebooting, my computer freezes when I try to log in. I had the same result when I tried with sudo apt install nvidia-driver-415 and sudo ubuntu-drivers autoinstall.
    • When I try to install nvidia 400 (sudo apt install nvidia-driver-400), I get the following :
      E: Unable to locate package nvidia-driver-400
NB: weirdly, Firefox doesn't work anymore, while Chrome does.
SOLUTION: After purging Nvidia, simply remove the xorg.conf file in /etc/X11. It doesn't make the Nvidia driver works, but at least Nouveau works.
Léo S.
  • 103
You are using a driver that is not compatible with your card. You will need to install one of the other pro drivers that are available (or revert to nouveau).
1. Drop to a command shell:
Press ctrl+alt+f2 and log in.
2. Purge out NVIDIA
sudo apt-get purge nvidia*
Now you can reboot and you will be running on Nouveau and we can make sure you have the right NVIDIA drivers.
3. Make sure you have Correct Nvidia
sudo apt update
sudo nvidia-xconfig
Then reboot and you should be good to go. If you need functionality from the 400 series drivers, try installing the 400 (not 415 or autoinstall) and see if it works. Otherwise stick with 390 as I personally find it less buggy.
4. If you want to test other drivers or see what's available:
As outlined in this post, you can do the following:
sudo ubuntu-drivers list
Will show all the driver packages which apply to your current system. You can then
to install all the packages you need, or you can do:
sudo ubuntu-drivers devices
to show you which devices need drivers, and their corresponding package names.
5. Rename old xorg.conf file and regenerate it
If you have bad configuration in your xorg.conf file you may need a new one. So rename the old one:
sudo mv /etc/X11/xorg.conf /etc/x11/xorg.conf.bak
And run nvidia-xconfig again:
sudo nvidia-xconfig
Get into terminal. There is a login option to do this. You just need the terminal for this. You could try to get into a terminal by pressing ctrl-alt-f1 or ctrl-alt-f2.
Anyway, once you are in a terminal type:
Then reboot.
Marc
  • 349
So thanks to @JoshuaBesneatte, I found the solution to get back to the original driver (Nouveau) :
  1. Purge Nvidia and reboot (see @JoshuaBesneatte answer) ;
  2. If you have tried to install Nvidia drivers before, you may need to get the original configuration file back (especially if you have used sudo nvidia-xconfig). To do so, remove the xorg.conf file in /etc/11/.
I still can't make the Nvidia drivers work, but at least I have a working driver so I'm fine.
Léo S.
  • 103
