How do I get Quickly to use Gvim (or just vim in a terminal) as its default text editor instead of Gedit?
If this can be done, I must be doing it wrong...
Ubuntu 10.10 AMD64.
brews
  • 233
I assume you mean you want to change the editor that Quickly loads when you ask it to.
Well I did some sleuthing... I'll show you what I did followed by the answer.
  1. I fired off this command:
    sudo find / -name "*quickly*" -exec grep gedit {} \;
    That searches for all files with quickly in and then greps them for gedit. It was a long shot -- I should have refined the search so it was any paths with quickly in but it matched!
    Binary file /usr/share/quickly/templates/ubuntu-application/internal/quicklyutils.pyc matches
        editor = "gedit"
  2. I opened up /usr/share/quickly/templates/ubuntu-application/internal/quicklyutils.py (not the compiled version) in nano, searched for gedit and saw:
    def get_quickly_editors():
        '''Return prefered editor for ubuntu-application template'''
        editor = "gedit"
        default_editor = os.environ.get("EDITOR")
        if not default_editor:
            default_editor = os.environ.get("SELECTED_EDITOR")
        if default_editor:
           editor = default_editor
        return editor
  3. From that you can see it asks for the environment value EDITOR!
    Just run your quickly commands as:
    env EDITOR=gvim quickly edit
    or export it to persist
    export EDITOR=gvim
    quickly edit
    Add the export line to your ~/.bashrc line if you want it to persist between sessions.
Oli
  • 299,380
After you install GVim , using Synaptic Package Manager, then it should be available in the Applications menu and you can right click on it and add the application shortcut to your desktop.
djangofan
  • 3,874
What about sudo update-alternatives –config editor? It will change the system default editor so you do not have to change individual program preferences..
SW1
  • 111
