I used this answer to change the editor used with quickly and it worked, however now,when I type quickly edit the command line stays on the open and does not allow me to enter other commands as long as Sublime Text 2 is open. I realise this is a daft question, but I can't seem to find a way to get around it.
Asked
Active
Viewed 1.0k times
boywithaxe
- 2,130
Set the EDITOR environment variable to sublime and then quickly edit will use it:
export EDITOR=/usr/bin/subl
Just add the above line to your ~/.bashrc file
It does this because gedit is programmed to do that when you run it from the command line. You can make quickly do that with other editors by using quickly edit &.
Edit: I wrote a Perl script that will run the editor as a as a child of init so when you close the terminal the editor will remain open: script
You can set the following vaiables at the top of the script:
- command: the command to be run
- stdout: The standard output to be passed to the command (must be set or it will still output to terminal)
- stderr: The standard output to be passed to the command (must be set or it will still output to terminal)
Sam Bickley
- 530
