43
Not experiened with Ubuntu. Set up a dhcp server about a year ago but don't remember the command to see the active leases.
keith
  • 531
7 Answers7
38
Try checking the lease file /var/lib/dhcp/dhcpd.leases
32
Our organization uses a Python script, as posted below, to examine the /var/lib/dhcp/dhcpd.leases file:
#!/usr/bin/python
import datetime, bisect
def parse_timestamp(raw_str):
        tokens = raw_str.split()
        if len(tokens) == 1:
                if tokens[0].lower() == 'never':
                        return 'never';
                else:
                        raise Exception('Parse error in timestamp')
        elif len(tokens) == 3:
                return datetime.datetime.strptime(' '.join(tokens[1:]),
                        '%Y/%m/%d %H:%M:%S')
        else:
def timestamp_is_ge(t1, t2):
        if t1 == 'never':
                return True
        elif t2 == 'never':
                return False
        else:
                return t1 >= t2
def timestamp_is_lt(t1, t2):
        if t1 == 'never':
                return False
        elif t2 == 'never':
                return t1 != 'never'
        else:
                return t1 < t2
def timestamp_is_between(t, tstart, tend):
        return timestamp_is_ge(t, tstart) and timestamp_is_lt(t, tend)
def parse_hardware(raw_str):
        if len(tokens) == 2:
                return tokens[1]
        else:
                raise Exception('Parse error in hardware')
def strip_endquotes(raw_str):
        return raw_str.strip('"')
def identity(raw_str):
        return raw_str
def parse_binding_state(raw_str):
                return tokens[1]
        else:
                raise Exception('Parse error in binding state')
def parse_next_binding_state(raw_str):
                return tokens[2]
        else:
                raise Exception('Parse error in next binding state')
def parse_rewind_binding_state(raw_str):
                return tokens[2]
        else:
def parse_leases_file(leases_file):
        valid_keys = {
                'starts':               parse_timestamp,
                'ends':                 parse_timestamp,
                'tstp':                 parse_timestamp,
                'tsfp':                 parse_timestamp,
                'atsfp':                parse_timestamp,
                'cltt':                 parse_timestamp,
                'hardware':             parse_hardware,
                'binding':              parse_binding_state,
                'next':                 parse_next_binding_state,
                'rewind':               parse_rewind_binding_state,
                'uid':                  strip_endquotes,
                'client-hostname':      strip_endquotes,
                'option':               identity,
                'set':                  identity,
                'on':                   identity,
                'abandoned':            None,
                'bootp':                None,
                'reserved':             None,
        leases_db = {}
        lease_rec = {}
        in_lease = False
        in_failover = False
        for line in leases_file:
                if line.lstrip().startswith('#'):
                        continue
                tokens = line.split()
                if len(tokens) == 0:
                        continue
                key = tokens[0].lower()
                if key == 'lease':
                        if not in_lease:
                                ip_address = tokens[1]
                                lease_rec = {'ip_address' : ip_address}
                                in_lease = True
                        else:
                                raise Exception('Parse error in leases file')
                elif key == 'failover':
                        in_failover = True
                elif key == '}':
                        if in_lease:
                                for k in valid_keys:
                                        if callable(valid_keys[k]):
                                                lease_rec[k] = lease_rec.get(k, '')
                                        else:
                                                lease_rec[k] = False
                                ip_address = lease_rec['ip_address']
                                if ip_address in leases_db:
                                        leases_db[ip_address].insert(0, lease_rec)
                                else:
                                        leases_db[ip_address] = [lease_rec]
                                lease_rec = {}
                                in_lease = False
                        elif in_failover:
                                in_failover = False
                                continue
                        else:
                elif key in valid_keys:
                        if in_lease:
                                value = line[(line.index(key) + len(key)):]
                                value = value.strip().rstrip(';').rstrip()
                                if callable(valid_keys[key]):
                                        lease_rec[key] = valid_keys[key](value)
                                else:
                                        lease_rec[key] = True
                        else:
                else:
                        if in_lease:
        if in_lease:
        return leases_db
def round_timedelta(tdelta):
        return datetime.timedelta(tdelta.days,
                tdelta.seconds + (0 if tdelta.microseconds < 500000 else 1))
def timestamp_now():
        n = datetime.datetime.utcnow()
        return datetime.datetime(n.year, n.month, n.day, n.hour, n.minute,
                n.second + (0 if n.microsecond < 500000 else 1))
def lease_is_active(lease_rec, as_of_ts):
        return timestamp_is_between(as_of_ts, lease_rec['starts'],
                lease_rec['ends'])
def ipv4_to_int(ipv4_addr):
        parts = ipv4_addr.split('.')
        return (int(parts[0]) << 24) + (int(parts[1]) << 16) + \
                (int(parts[2]) << 8) + int(parts[3])
def select_active_leases(leases_db, as_of_ts):
        retarray = []
        sortedarray = []
        for ip_address in leases_db:
                lease_rec = leases_db[ip_address][0]
                if lease_is_active(lease_rec, as_of_ts):
                        ip_as_int = ipv4_to_int(ip_address)
                        insertpos = bisect.bisect(sortedarray, ip_as_int)
                        sortedarray.insert(insertpos, ip_as_int)
                        retarray.insert(insertpos, lease_rec)
        return retarray
myfile = open('/var/lib/dhcp/dhcpd.leases', 'r')
leases = parse_leases_file(myfile)
myfile.close()
now = timestamp_now()
report_dataset = select_active_leases(leases, now)
print('+------------------------------------------------------------------------------')
print('| DHCPD ACTIVE LEASES REPORT')
print('+-----------------+-------------------+----------------------+-----------------')
print('| IP Address      | MAC Address       | Expires (days,H:M:S) | Client Hostname ')
for lease in report_dataset:
        print('| ' + format(lease['ip_address'], '<15') + ' | ' + \
                format(lease['hardware'], '<17') + ' | ' + \
                format(str((lease['ends'] - now) if lease['ends'] != 'never' else 'never'), '>20') + ' | ' + \
                lease['client-hostname'])
print('| Total Active Leases: ' + str(len(report_dataset)))
print('| Report generated (UTC): ' + str(now))
dfsmith
  • 103
11
Try enter this command:
dhcp-lease-list
11
If you are using NetworkManager (which is default in many distributions) the .lease files is located in /var/lib/NetworkManager
$ sudo ls -al /var/lib/NetworkManager/*.lease
-rw-r--r-- 1 root root 399 Jun 12 10:23 /var/lib/NetworkManager/dhclient-6aef9d76-0f6a-46e3-8235-a4405a695b1a-eth0.lease
-rw-r--r-- 1 root root 856 Jun 12 10:30 /var/lib/NetworkManager/dhclient-86e97e19-0a11-4606-8edf-5a179ec6f82e-eth0.lease
-rw-r--r-- 1 root root 800 Jun 12 10:30 /var/lib/NetworkManager/dhclient-d0f4b29f-3059-4f55-a8d2-34db34310384-wlan0.lease
Here's a great command using CLI - You can go to the directory where dhcpd.log file is located and do:
tail -f dhcpd.log
That will show you leases as they are being issued by the server in real time.
You can also do:
cat /var/lib/dhcpd/dhcpd.leases to see leases that are in the lease file dhcpd.leases
BuZZ-dEE
  • 14,533
P. Scott
  • 61
I use this script:
#!/usr/bin/perl
my $VERSION=0.03;
my $leases_file = "/var/lib/dhcp/dhcpd.leases";
use strict;
use Date::Parse;
my $now = time;
my %seen;       # leases file has dupes (because logging failover stuff?). This hash will get rid of them.
open(L, $leases_file) or die "Cant open $leases_file : $!\n";
undef $/;
my @records = split /^lease\s+([\d\.]+)\s*\{/m, <L>;
shift @records; # remove stuff before first "lease" block
## process 2 array elements at a time: ip and data
foreach my $i (0 .. $#records) {
    next if $i % 2;
    my $ip;
    ($ip, $_) = @records[$i, $i+1];
    s/^\n+//;     # && warn "leading spaces removed\n";
    s/[\s\}]+$//; # && warn "trailing junk removed\n";
    my ($s) = /^\s* starts \s+ \d+ \s+ (.*?);/xm;
    my ($e) = /^\s* ends   \s+ \d+ \s+ (.*?);/xm;
    my $start = str2time($s);
    my $end   = str2time($e);
    my %h; # to hold values we want
    foreach my $rx ('binding', 'hardware', 'client-hostname') {
        my ($val) = /^\s*$rx.*?(\S+);/sm;
        $h{$rx} = $val;
    my $formatted_output;
    if ($end && $end < $now) {
        $formatted_output =
            sprintf "%-15s : %-26s "              . "%19s "         . "%9s "     . "%24s    "              . "%24s\n",
                    $ip,     $h{'client-hostname'}, ""              , $h{binding}, "expired"               , scalar(localtime $end);
    else {
        $formatted_output =
            sprintf "%-15s : %-26s "              . "%19s "         . "%9s "     . "%24s -- "              . "%24s\n",
                    $ip,     $h{'client-hostname'}, "($h{hardware})", $h{binding}, scalar(localtime $start), scalar(localtime $end);
    next if $seen{$formatted_output};
    $seen{$formatted_output}++;
    print $formatted_output;
You may want to adapt it to suit your needs.
There are also Perl modules which you may want to try if you have a vague notion of Perl: Net::ISC::DHCPd::Leases, POE::Filter::DHCPd::Lease or Text::DHCPLeases.
The last one can be installed with
sudo apt-get install libtext-dhcpleases-perl
The others with cpan -i.
Unfortunately, I haven't tried any of them, because I already had my script when I noticed them.
mivk
  • 5,811
If you want something in a GUI, take a look at Glass. It runs as a web-app, and provides access to your DHCPd config file, as well as the leases. It uses graphs and stats, which are helpful if you have multiple subnets or pools.
I also like that it alerts me if activity seems off - devices not getting addresses en masse, or too many requests from single clients. I've been using it for a month now, and I love it.
