I followed step-by-step from this site :
Installing Ubuntu inside Windows using VirtualBox
This is my system info:
System Information
Time of this report: 11/14/2012, 22:40:29
Machine name: CHRISTOPHER-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 02/05/10 19:13:52 Ver: 08.00.10
Processor: Intel® Core™ i5-2500K CPU @ 3.30GHz (4 CPUs), ~3.3GHz
Memory: 8192MB RAM
Available OS Memory: 8174MB RAM
Page File: 2227MB used, 14117MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Previously: Crashed in Direct3D (stage 2). Re-running DxDiag with “dontskip” command line parameter or choosing not to bypass information gathering when prompted might result in DxDiag successfully obtaining this information
I get the following VirtualBox Error: Failed to open a session for the virtual machine Ubuntu 64bit.
    VT-x features locked or unavailable in MSR.
    (VERR_VMX_MSR_LOCKED_OR_DISABLED).
    Result Code: E_FAIL (0x80004005)
    Component: Console
    Interface: IConsole {db7ab4ca-2a3f-4183-9243-c1208da92392}
I have no idea what's going on. I got Ubuntu up on running on my laptop, but I just got a desktop and I can't seem to get it working.
Downloaded ubuntu-12.04.1-desktop-i386 from Ubuntu 12.04.1 LTS (Precise Pangolin)
zyeek
  • 131
6 Answers6
For optimal performance of Virtual Box we need to enable VT-x (on Intel systems) or AMD-V (for AMD systems) in our BIOS settings in case our CPU has this feature.
To use this virtualization technology we then can enable this in the system settings for a virtual machine from Virtual Box Manager (Settings -> System -> Acceleration).
By doing so we are even able to run a 64-bit guest on a 32-bit host.
The architecture of the virtual machine (32- vs. 64-bit) also needs to be defined in the machine's General settings. In your case when installing the -i386-version this would be 32-bit (for 64-bit use the -amd64-images).
See also the following question: amd64 virtual machine in virtualbox
Takkat
  • 144,580
On my [new] HP Envy Phoenix (h9-1420t) I was surprised to find this BIOS setting in:
Security -> System Security -> Virtualization Technology (VTx/VTd) > disabled
sar
The Virtualbox error reported is related to VTx functionality in the host machine BIOS - check that VTx is enabled there (not in the guest machine virtual bios)
Important note: - in some buggy BIOSes, it may help to try setting it both on or off (it should really be enabled) if this does not work as expected - my HP workstation BIOS is buggy like this - the host BIOS displays it wrongly.
Once VTx is correctly enabled, it should be possible to use more than one virtual processor when running in a VTx enabled multicore host. It should also be possible to run 64bit guest machines on a 32 host, but again, only if VTx is enabled on the host.
-1
Maybe you are using more than one CPU or processor in your virtual machine. Open it again and retry. Setting -> System -> Processor
Oyibo
  • 1,917
user93983
  • 19
I figured out that using the escape key and then pressing f10 key. The BIOS menu came.
-3
You have to be an administrator to run Virtualbox. Right click and choose "Run as administrator"
