I connected USB cable from Nexus 7 running Ubuntu to my Ubuntu laptop but there is no new USB device found when I run lsusb. Is this function supported?
UPDATE Please take a look below for go-mtpfs example. go-mtpfs is much more reliable, but the instructions remain very similar.
Automatically mounting Nexus 7
Allow non-root users to mount fuse devices:
sudo vim /etc/fuse.conf
Un-comment **user_allow_other**.
Install mtpfs
sudo apt-get install mtp-tools mtpfs
Make mount point
sudo mkdir /mnt/nexus7
chown youruser:youruser /mnt/nexus7
Add udev rules
sudo gedit /etc/udev/rules.d/99-android.rules
#Nexus7
SUBSYSTEM=="usb", SYSFS{idVendor}=="18d1", MODE="0666"
sudo chmod +x /etc/udev/rules.d/99-android.rules
Add Nexus7 to fstab
sudo vim /etc/fstab
mtpfs /mnt/nexus7 fuse user,noauto,allow_other,defaults 0 0
Restart udev
sudo service udev restart
Access device
mount /mnt/nexus7
umount /mnt/nexus7
- 11,658
A blog post by Bilal Akhtar has a supposedly more reliable way to connect to Android 4.0+ devices from Ubuntu. The steps are summarized here:
Install the
go-mtpfslibrary, which you'll be using to connect:sudo apt-get install golang fuse git-core libmtp-dev libfuse-dev sudo adduser $USER fuse mkdir /tmp/go GOPATH=/tmp/go go get github.com/hanwen/go-mtpfs sudo mv /tmp/go/bin/go-mtpfs /usr/bin/ mkdir ~/MyAndroidNote: At some point during installation, a screen may come up in your terminal asking if you want to share information about public Go packages you install with the developers. Feel free to answer this question however you want.
Mount your Nexus 7 or whatever using this command after plugging it into your USB port:
go-mtpfs ~/MyAndroid &When you are finished, unmount your device by using this command:
fusermount -u ~/MyAndroid
I would also like to thank James Gifford for pointing this article out to me on Google+. ;)
- 14,911
I found that it doesn't work with cheap cables - if it doesn't even show "Nexus" in lsusb, your cable is bad. Try a better one.
- 1,440
If the Nexus tablet has the Software Data Cable app available, this program will let you easily transfer files via a wireless link. See:
http://linuxnorth.wordpress.com/2012/04/23/a100-to-ubuntu-file-transfer/
and
http://linuxnorth.wordpress.com/2012/04/24/software-data-cable-addendum/
- 2,692
In contrast to all the other answers I would still claim that it's not yet possible at all. The question is clearly about "Nexus 7 running Ubuntu" and as far as I understand there is no special service in this first Ubutu port for the Nexus 7 that acts as a USB device. I have a Nexus 7 running Ubuntu here and didn't succeed with any of these solutions mentioned.
I think, all answers so far target Nexus 7 running Android.
Please correct me if I am wrong.
- 1,019
Install this PPA : https://launchpad.net/~langdalepl/+archive/gvfs-mtp
Update and upgrade.
Hey presto, working MTP support that automounts a Nexus 7 as a browsable folder in Nautilus.
- 5,256
