I would like Ubuntu to open up a terminal window and apply the following code upon login:
xrandr --newmode "1280x1024_60.00" 109.00 1280 1368 1496 1712 1024 1027 1034 1063 -hsync +vsync
xrandr --addmode VGA1 1280x1024_60.00
xrandr --output VGA1 --mode 1280x1024_60.00
I usually have to copy/paste the xrandr lines into terminal manually, just wondering if there was shortcut.
I'm using 12.10 btw.
thanks in advance!
devav2
  • 37,290
Create a .sh file and copy paste the contents.
vi file_name.sh
#!/bin/bash
and save the file. Change the permissions.
  chmod +x file_name.sh
Now open dash. Search for "Startup Applications" and open it.
Click "Add" and browse for the file that you created earlier(file_name.sh) and add it.
Check this Q&A for detailed answered about adding a program to Startup Applications
devav2
  • 37,290
You should put this in a script in ~/bin and call it from startup applications.
First make the ~/bin folder if you don't already have one:
mkdir ~/bin
Every time you boot, this folder will be automatically added to your paths
Next, create the new file and start the edit:
gedit ~/bin/setscreen
and past the contents into it:
#!/bin/bash
Then save and exit gedit.
Now you will need to change the file so it is an executable script:
chmode +x ~/bin/setscreen
You can now call the program at any time by opening a terminal or console and typing:
setscreen
You should now open up startup applications and add the file /home/username/setscreen and make sure it is selected for start.
Really though, what you should be doing is adding this mode to the /etc/X11/xorg.conf file so that it is working correctly right from the login screen. This is a different and more complex problem however, and you should probably ask a separate question on how to do this.
fabricator4
  • 8,471
  • 37
  • 39
