Possible Duplicate:
Desktop does not show when I installed nvidia drivers!
I have installed Ubuntu 12.1 and own the nvidia gtx 550 ti (no integrated video). Installed it just fine but the buttons and text seem to get scrambled if using the nouveau drivers I guess. I tried installing the proprietary drivers manualy and from the Additional Drivers tab in software sources but every time I do that after it restarts the menus and icons dissapear an the only way getting them back is to revert to the nouveau drivers. I've tried noumerous attempts ending up reinstalling it. Any help would be apreciated, thanks.
Phill
There are many threads regarding installing Nvidia drivers under Ubuntu 12.10. While I've found the new distribution to be quite lacking in this regard (among others), here's what worked for me.
After installing (i.e., upgrading or fresh install)
  1. Get all updates using the software updater and reboot as required
  2. Run: sudo apt-get install linux-source
  3. Run: sudo apt-get install linux-headers-generic
  4. Run: sudo apt-get install nvidia-current updates
  5. Reboot... run nividia-settings to verify the driver is installed and the card is recognized.
This has worked on a machine with a GTX-460 and another with a GTS-250 card installed.
devav2
  • 37,290
Mark
you can try to install recommended drivers ... dont use recent drivers ..
else
http://www.nvidia.in/Download/index.aspx?lang=en-in
use automatic driver finder it will find drivers for you !!
swapyonubuntu
  • 1,002
