I cannot install any package in the server, as I am newbie with server. In the morning I found that some, I am not able to install any package from command line in the server. Now every package is now manually downloaded packages and then installed in the server.
Can anyone please tell me what is the issue and how could it be resolved?
OS: Ubuntu 10.04.4 LTS (64 Bit)
Below is the error:
iam@ubuntu$ sudo apt-get install pidgin
Reading package lists... Done
Building dependency tree
pidgin is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 102 not upgraded.
32 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
Traceback (most recent call last):
  File "/usr/bin/apt-listchanges", line 33, in <module>
    from ALChacks import *
  File "/usr/share/apt-listchanges/ALChacks.py", line 32, in <module>
    sys.stderr.write(_("Can't set locale; make sure $LC_* and $LANG are correct!\n"))
NameError: name '_' is not defined
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
    LANGUAGE = (unset),
    LC_ALL = (unset),
    LC_CTYPE = "UTF-8",
    LANG = "en_IN"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
Setting up shared-mime-info (0.71-1ubuntu2) ...
/var/lib/dpkg/info/shared-mime-info.postinst: line 13: 21935 Segmentation fault      update-mime-database.real /usr/share/mime
dpkg: error processing shared-mime-info (--configure):
 subprocess installed post-installation script returned error exit status 139
dpkg: dependency problems prevent configuration of libgtk2.0-0:
 libgtk2.0-0 depends on shared-mime-info; however:
  Package shared-mime-info is not configured yet.
dpkg: error processing libgtk2.0-0 (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of chromium-browser:
 chromium-browser depends on libgtk2.0-0 (>= 2.20.0); however:
  Package libgtk2.0-0 is not configured yet.
dpkg: error processing chromium-browser (--configure):
dpkg: dependency problems prevent configuration of chromium-codecs-ffmpeg:
 chromium-codecs-ffmpeg depends on chromium-browser (>= 4.0.203.0~); however:
  Package chromium-browser is not configured yet.
dpkg: error processing chromium-codecs-ffmpeg (--configure):
dpkg: dependency problems prevent configuration of chromium-browser-l10n:
 chromium-browser-l10n depends on chromium-browser (= 18.0.1025.151~r130497-0ubuntu0.10.04.No apport report written because the error message indicates its a followup error from a previous failure.
                                                               No apport report written because MaxReports is reached already
                         1); however:
dpkg: error processing chromium-browser-l10n (--configure):
dpkg: dependency problems prevent configuration of libevdocument2:
 libevdocument2 depends on libgtk2.0-0 (>= 2.14.0); however:
dpkg: error processing libevdocument2 (--configure):
dpkg: dependency problems prevent configuration of libevview2:
 libevview2 depends on libevdocument2 (>= 2.29.5); however:
  Package libevdocument2 is not configured yet.
 libevview2 depends on libgtk2.0-0 (>= 2.20.0); however:
dpkg: error processing libevview2 (--configure):
dpkg: dependency problems prevent configuration of evince:
 evince depends on libevdocument2 (>= 2.29.5); however:
 evince depends on libevview2 (>= 2.29.No apport report written because MaxReports is reached already
                                                       5); however:
  Package libevview2 is not configured yet.
 evince depends on libgtk2.0-0 (>= 2.16.0); however:
 evince depends on shared-mime-info; however:
dpkg: error processing evince (--configure):
dpkg: dependency problems prevent configuration of firefox:
 firefox depends on libgtk2.0-0 (>= 2.20.0); however:
dpkg: error processing firefox (--configure):
dpkg: dependency problems prevent configuration of gcalctool:
 gcalctool depends on libgtk2.0-0 (>= 2.18.0); however:
dpkg: error processing gcalctool (--configure):
dpkg: dependency problems prevent configuration of libgdict-1.0-6:
 libgdict-1.0-6 depends on libgtk2.0-0 (>= 2.18.0); however:
dpkg: error processing libgdict-1.0-6 (--configure):
dpkg: dependency problems prevent configuration of gnome-utils:
 gnome-utils depends on libgdict-1.0-6 (>= 2.23.90); however:
  Package libgdict-1.0-6 is not configured yet.
 gnome-utils depends on libgtk2.0-0 (>= 2.18.0); however:
dpkg: error processing gnome-utils (--configure):
dpkg: dependency problems prevent configuration of gtk2-engines-pixbuf:
 gtk2-engines-pixbuf depends on gtk2.0-binver-2.10.0; however:
  Package gtk2.0-binver-2.10.0 is not installed.
  Package libgtk2.0-0 which provides gtk2.0-binver-2.10.0 is not configured yet.
 gtk2-engines-pixbuf depends on libgtk2.0-0 (= 2.20.1-0ubuntu2.1); however:
dpkg: error processing gtk2-engines-pixbuf (--configure):
dpkg: dependency problems prevent configuration of libedataserverui1.2-8:
 libedataserverui1.2-8 depends on libgtk2.0-0 (>= 2.14.0); however:
dpkg: error processing libedataserverui1.2-8 (--configure):
dpkg: dependency problems prevent configuration of libgail18:
 libgail18 depends on libgtk2.0-0 (= 2.20.1-0ubuntu2.1); however:
dpkg: error processing libgail18 (--configure):
dpkg: dependency problems prevent configuration of libgtk2.0-bin:
 libgtk2.0-bin depends on libgtk2.0-0 (>= 2.20.1-0ubuntu2.1); however:
dpkg: error processing libgtk2.0-bin (--configure):
dpkg: dependency problems prevent configuration of libgtk2.0-dev:
 libgtk2.0-dev depends on libgtk2.0-0 (= 2.20.1-0ubuntu2.1); however:
dpkg: error processing libgtk2.0-dev (--configure):
dpkg: dependency problems prevent configuration of libnotify-dev:
 libnotify-dev depends on libgtk2.0-dev (>= 2.10); however:
  Package libgtk2.0-dev is not configured yet.
dpkg: error processing libnotify-dev (--configure):
dpkg: dependency problems prevent configuration of network-manager-gnome:
 network-manager-gnome depends on libgtk2.0-0 (>= 2.16.0); however:
dpkg: error processing network-manager-gnome (--configure):
dpkg: dependency problems prevent configuration of openoffice.org-core:
 openoffice.org-core depends on libgtk2.0-0 (>= 2.10); however:
dpkg: error processing openoffice.org-core (--configure):
dpkg: dependency problems prevent configuration of openoffice.org-draw:
 openoffice.org-draw depends on openoffice.org-core (= 1:3.2.0-7ubuntu4.4); however:
  Package openoffice.org-core is not configured yet.
dpkg: error processing openoffice.org-draw (--configure):
dpkg: dependency problems prevent configuration of openoffice.org-impress:
 openoffice.org-impress depends on openoffice.org-core (= 1:3.2.0-7ubuntu4.4); however:
 openoffice.org-impress depends on openoffice.org-draw (= 1:3.2.0-7ubuntu4.4); however:
  Package openoffice.org-draw is not configured yet.
dpkg: error processing openoffice.org-impress (--configure):
dpkg: dependency problems prevent configuration of pidgin:
 pidgin depends on libgtk2.0-0 (>= 2.18.0); however:
dpkg: error processing pidgin (--configure):
                                                              Setting up update-manager (1:0.134.12.1) ...
dpkg: error processing update-manager (--configure):
 subprocess installed post-installation script returned error exit status 245
                                                              dpkg: dependency problems prevent configuration of update-notifier:
 update-notifier depends on libgtk2.0-0 (>= 2.14.0); however:
 update-notifier depends on update-manager; however:
  Package update-manager is not configured yet.
dpkg: error processing update-notifier (--configure):
                                                              dpkg: dependency problems prevent configuration of xulrunner-1.9.2:
 xulrunner-1.9.2 depends on libgtk2.0-0 (>= 2.18.0); however:
dpkg: error processing xulrunner-1.9.2 (--configure):
dpkg: dependency problems prevent configuration of xulrunner-1.9.2-dev:
 xulrunner-1.9.2-dev depends on xulrunner-1.9.2 (= 1.9.2.28+build1+nobinonly-0ubuntu0.10.04.1); however:
  Package xulrunner-1.9.2 is not configured yet.
 xulrunner-1.9.2-dev depends on libnotify-dev; however:
  Package libnotify-dev is not configured yet.
dpkg: error processing xulrunner-1.9.2-dev (--configure):
                                            dpkg: dependency problems prevent configuration of icedtea6-plugin:
 icedtea6-plugin depends on xulrunner-1.9.2; however:
 icedtea6-plugin depends on libgtk2.0-0 (>= 2.8.0); however:
dpkg: error processing icedtea6-plugin (--configure):
Setting up libgweather-common (2.30.0-0ubuntu1.1) ...
dpkg: error processing libgweather-common (--configure):
                                                              dpkg: dependency problems prevent configuration of libgweather1:
 libgweather1 depends on libgtk2.0-0 (>= 2.11.0); however:
 libgweather1 depends on libgweather-common (>= 2.24.0); however:
  Package libgweather-common is not configured yet.
dpkg: error processing libgweather1 (--configure):
dpkg: dependency problems prevent configuration of openoffice.org-style-galaxy:
 openoffice.org-style-galaxy depends on openoffice.org-core (>= 1:3.2.0~beta); however:
                                                              dpkg: error processing openoffice.org-style-galaxy (--configure):
dpkg: dependency problems prevent configuration of openoffice.org-common:
 openoffice.org-common depends on openoffice.org-style-default | openoffice.org-style; however:
  Package openoffice.org-style-default is not installed.
  Package openoffice.org-style-galaxy which provides openoffice.org-style-default is not configured yet.
  Package openoffice.org-style is not installed.
  Package openoffice.org-style-galaxy which provides openoffice.org-style is not configured yet.
                                                              dpkg: error processing openoffice.org-common (--configure):
 shared-mime-info
 libgtk2.0-0
 chromium-browser
 libevdocument2
 libevview2
 evince
 firefox
 gcalctool
 libgdict-1.0-6
 gnome-utils
 gtk2-engines-pixbuf
 libgail18
 libgtk2.0-bin
 libgtk2.0-dev
 libnotify-dev
 openoffice.org-core
 openoffice.org-draw
 pidgin
 update-manager
 update-notifier
 xulrunner-1.9.2
 xulrunner-1.9.2-dev
 icedtea6-plugin
 libgweather-common
 libgweather1
While typing command in terminal, command is not auto-completing.
Mateng
  • 556
I hope you are not mixing up several topics.
First, your report states:
Meaning: Pidgin is already installed.
Do you really need Pigdin on your server? Also, do you need Chrome?
Second: You have some dependancy problems. Check that your /etc/sources.list is clean. A lot of good tips on how to solve dependancy probems can be found here: How do I resolve unmet dependencies after adding a PPA?. Try with a very minimal sources.list:
###### Ubuntu Main Repos
deb http://in.archive.ubuntu.com/ubuntu/ lucid main
deb-src http://in.archive.ubuntu.com/ubuntu/ lucid main
###### Ubuntu Update Repos
deb http://in.archive.ubuntu.com/ubuntu/ lucid-security main
deb-src http://in.archive.ubuntu.com/ubuntu/ lucid-security main
Then do sudo apt-get clean or sudo apt-get autoclean Continue with solutions from the link above. If satisfied, you can extend your sources.list line by line. Tip: Ubuntu Sources List Generator
Third: Not autocompleting might be a problem of your shell. Check if this resolves if you do chsh -s /bin/bash or try another shell. (More)
Fourth: Try installing a proper Locale (some locale errors appeared above):
sudo apt-get install language-pack-en-base
sudo dpkg-reconfigure locales
Mateng
  • 556
