Possible Duplicate:
How to remove Ubuntu and put Windows back on?
I had my Acer Aspire 3000 as a dual boot XP/ubuntu 9.10 a couple years ago. I recently blew the dust of it and wanted to upgrade to 7/Ubuntu 12.10 so I began by formatting the Ubuntu side of the partition and apparently damaged the mbr as I could only get black screen with the error message:
GRUB loading...
error: no such partition
grub rescue>
I then slaved the hdd to my win7 desktop and formatted the entire drive, both sides of the partition then reinstalled it in the Acer and tried to install win7. Upon starting the Acer I got the same error message:
GRUB loading...
grub rescue>
I then tried to reinstall Ubuntu 9.10 as I have an Ubuntu produced installation cd. Same result.
Next day I received a new battery I had ordered for the Acer. I plugged it and the power supply in and hit the power button just to see if I at least could charge the battery but to my surprise Ubuntu 9.10 began to install, so I let it and it did. Now the hard drive shows 58 gb and 2.5gb partitions neither of which is formatted NTFS for/by windows. I am guessing that the GRUB/mbr was repaired somehow by the Ubuntu reinstallation.
My question, should you choose to accept it; How can I get to my goal of dual boot win7/Ubuntu 12.10. I am a beginner and don't know much about linux or the terminology. Thank you for your thoughts and help.
770
the deal is, you don't upgrade it 9.10 to 12.10 because you can't. You have do this long way instead:
9.10 --> 10.04 --> 12.04 --> 12.10
of course it's MUCH easier to make a fresh install of 12.10
install windows 7 first then install 12.10 is the easiest and fastest way to get your dual boot setup.
Alvar
  • 17,038
You can't. Acer Aspire 3000 has only 256 mb of memory. Unless you have upgraded it you are not going to be able to load neither Windows 7, nor Ubuntu 12.04 on it. Both need way more memory.
In my experience Windows 7 needs at least 2Gb to run smoothly and Ubuntu 12.04 at least 1 Gb. Both will refuse to install with only 256 Mb.
You should be able to install Lubuntu, a lighter version of Ubuntu, 12.04 on it and make it usable, but even them you will be short of RAM. Expect it to be more bare-bones and have more rough edges than core Ubuntu.
Javier Rivera
  • 35,434
