I enabled the Embedded terminal plug-in for gedit, but it only appears as in the picture. I can't type anything!
Is there a way to fix this? Or am I missing something?
stupidity
  • 413
I had a similar problem before. The problem turns out to be the color of the words in this embedded terminal is white, so you can't see them. Follow this linkMake gedit embedded terminal colours the same as the default terminal, you could change the color to be normal black.
