16
I'm trying to add the ppa repository (as a root) with the following command:
export HTTP_PROXY="http://firstname.surname@xxx.com:my_pass@165.x.x.232:8080"
add-apt-repository ppa:nilarimogard/webupd8
Traceback (most recent call last):
  File "/usr/bin/add-apt-repository", line 125, in <module>
    ppa_info = get_ppa_info_from_lp(user, ppa_name)
  File "/usr/lib/python2.7/dist-packages/softwareproperties/ppa.py", line 84, in get_ppa_info_from_lp
    curl.perform()
pycurl.error: (56, 'Received HTTP code 407 from proxy after CONNECT')
Unfortunately it doesn't work. Looks like curl is connecting to the proxy, but the proxy says that Authentication is Required. I've tried with .curlrc, http_proxy env instead, but it doesn't work.
strace -e network,write -s1000 add-apt-repository ppa:nilarimogard/webupd8
socket(PF_INET6, SOCK_DGRAM, IPPROTO_IP) = 4
socket(PF_INET, SOCK_STREAM, IPPROTO_TCP) = 4
connect(4, {sa_family=AF_INET, sin_port=htons(8080), sin_addr=inet_addr("165.x.x.232")}, 16) = -1 EINPROGRESS (Operation now in progress)
getsockopt(4, SOL_SOCKET, SO_ERROR, [0], [4]) = 0
getpeername(4, {sa_family=AF_INET, sin_port=htons(8080), sin_addr=inet_addr("165.x.x.232")}, [16]) = 0
getsockname(4, {sa_family=AF_INET, sin_port=htons(46025), sin_addr=inet_addr("161.20.75.220")}, [16]) = 0
sendto(4, "CONNECT launchpad.net:443 HTTP/1.1\r\nHost: launchpad.net:443\r\nUser-Agent: PycURL/7.22.0\r\nProxy-Connection: Keep-Alive\r\nAccept: application/json\r\n\r\n", 146, MSG_NOSIGNAL, NULL, 0) = 146
recvfrom(4, "HTTP/1.1 407 Proxy Authentication Required\r\nProxy-Authenticate: BASIC realm=\"proxy\"\r\nCache-Control: no-cache\r\nPragma: no-cache\r\nContent-Type: text/html; charset=utf-8\r\nProxy-Connection: close\r\nSet-Cookie: BCSI-CS-91b9906520151dad=2; Path=/\r\nConnection: close\
Maybe it's because there is @ sign in the username? Wget works with proxy fine.
Related: How do I add a repository from behind a proxy?
Environment
Ubuntu 12.04
curl 7.22.0 (x86_64-pc-linux-gnu) libcurl/7.22.0 OpenSSL/1.0.1 zlib/1.2.3.4 libidn/1.23 librtmp/2.3
curl Features: GSS-Negotiate IDN IPv6 Largefile NTLM NTLM_WB SSL libz TLS-SRP
UPDATE
When added credentials into .curlrc
cat ~/.curlrc
proxy = 165.x.x.232:8080
proxy-user = name.surname@xxx.com:mypass0
It seems to work for the plain curl.
curl www.google.com | head
* Proxy auth using Basic with user 'name.surname@xxx.com'
GET HTTP://www.google.com HTTP/1.1
Proxy-Authorization: Basic cmFmYWwud2llY3pvcmVrQHVi...3R0RDA=
HTTP/1.1 302 Found
Also HTTPS:
curl -v https://www.google.com | head
* Establish HTTP proxy tunnel to www.google.com:443
> CONNECT www.google.com:443 HTTP/1.1
> Host: www.google.com:443
    > User-Agent: curl/7.22.0 (x86_64-pc-linux-gnu) libcurl/7.22.0 OpenSSL/1.0.1     zlib/1.2.3.4 libidn/1.23 librtmp/2.3
< HTTP/1.1 200 Connection established
* Proxy replied OK to CONNECT request
* successfully set certificate verify locations
But still doesn't work when adding ppa certificate.
CURL HEADERS
Headers sent:
Proxy-Authorization: Basic cGVvcGxlcmVhbGx5c2hvdWxkQHNhbml0aXplcG9zdHM=
Reply:
PyCURL HEADERS
Headers sent:
Reply:
Proxy-Authenticate: BASIC realm="proxy"
It seems that PyCURL doesn't re-send any Authorization when requested.
kenorb
  • 10,944
Workaround if apt-get still works behind the proxy
  • add sources manually to /etc/apt/sources.list
  • add gpg key
Adding sources manually
I think on launchpad.net every ppa still contains a small description how to add sources manually. The launchpad site for your mentioned ppa ppa:nilarimogard/webupd8 is https://launchpad.net/~nilarimogard/+archive/webupd8. If you scroll down you see an expandable label Technical details about this PPA. If you expand it you find the description how to add sources manually. Add the following lines to mentioned /etc/apt/sources.list
deb http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu quantal main
deb-src http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu quantal main
Of course you have to adjust quantal to whatever version you are currently using.
Adding the Signing Key
The description also contains a signing key. This is important, so that your system can always verify that you actually access a trustworthy ppa-address. In case of your ppa that is 1024R/4C9D234C(can also be found under Technical details about this PPA), where the number behind the slash is important. You can add the fingerprint via the apt-key program. Typically you would perform the following command
 sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 4C9D234C
Adding if apt-key doesn't work through proxy
Since you already had problems with the add-apt-repository program this might not work either. So instead you can download and add the 1024 Bit key manually. If wget works you can do that in one step.
wget "http://keyserver.ubuntu.com:11371/pks/lookup?op=get&search=0x531EE72F4C9D234C" -O out && sudo apt-key add out && rm out
Otherwise safe "http://keyserver.ubuntu.com:11371/pks/lookup?op=get&search=0x531EE72F4C9D234C" in e.g. /path/key and use sudo apt-key add /path/key to add it.
Close with the usual
Afterwards you have to update the repository information apt-get update and then you should be able to download the packages.
Resources
My personal favorite on how to use the packaging mechanism (sadly in German): http://wiki.ubuntuusers.de/Paketquellen_freischalten/PPA
The launchpad version also mentions all the important points: https://help.launchpad.net/Packaging/PPA/InstallingSoftware
Since it is untypical to use apt-key in the described way I only found the information in the man pages, man apt-key.
Related answer that pretty much describes the standard way to install ppa's manually: https://askubuntu.com/a/38029/128349
LeoR
  • 393
Actually it seems to be much easier than the answer posted previously. You just need "sudo" to know that you are behind a proxy and it will work effortlessly. To do this, you need to export your proxy for http and https the way you usually do:
export http_proxy=http://username:password@host:port/
export https_proxy=https://username:password@host:port/
and then add Defaults env_keep="https_proxy" to then end of /etc/sudoers file. After this you should be able to add the ppa using the command:
sudo add-apt-repository ppa:the_ppa_you_want_to_add
or use
sudo -E add-apt-repository ppa:the_ppa_you_want_to_add
if you don't want to modify /etc/sudoers file. The -E option exports environment variables to the sudo user.
I have given a detailed description about this here on my blog.
jobin
  • 28,567
Make sure apt proxy is set like below
sudo vi /etc/apt/apt.conf
add following proxy settings and save the file
Acquire::http::proxy "http ://proxy.company.com:port/";
Acquire::https::proxy "https ://proxy.company.com:port/";
Acquire::ftp::proxy "ftp://proxy.company.com:port/";
in addition export following in Terminal before you run the command
export http_proxy=http ://proxy.company.com:port/
export https_proxy=https ://proxy.company.com:port/
This should work.
Eric Carvalho
  • 55,453
Manjula
