23
I am able to setup a link with another laptop (Win 7) and even able to send files (surprisingly around 3-4 MBps). But I am not able to locate where exactly the files are getting stored in my Ubuntu 12.04. Is there anyway where I can setup the default folders for it.
Jorge Castro
  • 73,717
8 Answers8
17
They are in /home/username/Public (in Ubuntu 13.04).
Eric Carvalho
  • 55,453
Ubuntu 14.04 (and confirmed still in 24.04):
If you configure Bluetooth file transfer using the "Personal file sharing" settings (gnome-file-share-properties), your files will be located in your Downloads folder (~/Downloads).
NotTheDr01ds
  • 22,082
You can open a terminal and do:
find ~ -name *filename or part of it*
~ means it'll search from /home, -name because you want to find a filename.
If you don't sudo you'll get a few permission denied (find couldn't access in read to check for filename) but that doesn't matter.
For me (using blueman on Ubuntu 18) they ended up in /home/anonymous/.cache/obexd/20200130_223605.jpg
Not sure who's the genius who thought this would be a good default....
Francky_V
  • 181
Yes search for "Personal File Sharing Preferences" in Applications from the Dash.
You'll get a menu of options and you can change Downloads as the primary folder to which files are bluetoothed to.
Normally files are saved in your /Home Folder check it out.
OmiPenguin
  • 2,342
To find Bluetooth inbox files, just type the name of the file you sent to your Linux computer in the terminal / command line like this: find ~ -type f -name "nameOfTheFile.txt"
You should be able to see something like this. ./.cache/obexd/nameofthefile.txt
This is the location where Bluetooth files are landing on Kali/Debian Linux, so from explorer just type in the following target. ~/.cache/obexd/
If you don“t like this location, change it by right clicking on the Bluetooth icon and going to Local Services>Transfer>Incoming Folder and changing it to the desired location.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
For me it was in /home/Public but if you already installed "Blueman applet" on you system, you can easily change the folder using its "Local Services" option
Kamil
  • 51
Any version of ubuntu just select File System in explorer and search public folder see your transferred files there then select make link and shift to desktop
Bipin
