Ubuntu 12.04 Wireless Disabled by Hardware Switch, rf kill unblock all, and rf kill list DOES NOT WORK! What next?
All I get is "Command "rf" not found"
mark
  • 69
the correct syntax
The reason for the error Command 'rf' not found is because you have accidentally added a space character between rf and kill
The correct syntax is rfkill command
where command is one of:
    help
    event
    list [IDENTIFIER]
    block IDENTIFIER
    unblock IDENTIFIER
where IDENTIFIER is the index no. of an rfkill switch or one of:
     all wifi wlan bluetooth uwb ultrawideband wimax wwan gps fm
Since you appear to be trying to unblock a particular device the syntax would be:
rfkill unblock all
You should note - rfkill unblock all will only release the device lock that has been created by the operating system - i.e. a soft-block.
If your device has been locked by a physical device - for example, physical switch, keyboard lock such as Fn+Function-key then the rfkill unblock all will not work - this is a so called hard-block
You can see the status of devices with rfkill list all - example results are:
rfkill list all
0: acer-wireless: Wireless LAN
    Soft blocked: no
    Hard blocked: no
1: brcmwl-0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
fossfreedom
  • 174,526
