Installing LibreOffice manually on Ubuntu 12.04 works great following the advice in this answer: https://askubuntu.com/a/182602/103893
It basically is a matter of downloading the most recent release from the LibreOffice site and running sudo apt-get remove libreoffice-core and sudo dpkg -i *.deb.
Doing the above I installed LibreOffice 3.6.3 and it works great.
But what is the best way to uninstall this new version of LibreOffice (for when the next release is coming along)?
Trying sudo apt-get remove libreoffice-core will not do anything, and sudo apt-get remove libreoffice3.6 does not seem to remove all packages installed with dpkg...?
I also just installed version 3.6.3 from the libreoffice website. Before installing with I purged the old files & libraries with this command:
sudo apt-get purge libreoffice*
edit: you also probably want to do this, too, before installing
sudo apt-get autoclean
and
sudo apt-get autoremove
philshem
  • 2,103
I just went through the same procedure as you and I did so by following the LO FAQ post on uninstalling previous version of community supplied packages.
The steps outlined in the FAQ require Synaptic Package Manager. You can install it with:
sudo apt-get install synaptic
From the FAQ:
Once you have ensured that Synaptic is installed on your system, proceed as follows to de-install an existing installation of LibreOffice:
  1. Launch the Synaptic Package Manager.
  2. Click in the Search box.
  3. Enter the string “libreoffice”. You may need to click on the “Search Results” button before you see this filtering string applied.
  4. This search will display a list of matching packages. In this list, there will be one package named simply “libreoffice3”. Right-click on that package name and, in the context-sensitive menu that opens, choose “Mark for Complete Removal”.
You will be prompted to accept the marking of a number of additional changes. Accept these additional changes.
In the packages list, scroll down until you see the first package that is not yet marked for removal. Right-click on that package name and, in the context-sensitive menu that opens, choose “Mark for Complete Removal”.
Do the same for the next package. You will be prompted to accept the marking of a number of additional changes. Accept these additional changes.
Continue right down to the bottom of the list and mark every single listed package for complete removal.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Glutanimate
  • 21,763
