18
I have installed an Ubuntu machine with two encrypted LUKS partitions: one for / and one for /home.
I've reinstalled the machine to upgrade to 10.04. Again, the / is installed using LUKS, and I'm able to mount the /home using:
mkdir /media/home
sudo cryptsetup luksOpen /dev/sda2 home
sudo mount -t ext3 /dev/mapper/home /media/home
The problem is, this cryptfs mapper disappears after boot, so I putting the appropriate line in fstab fails.
How do I set the cryptfs to prompt for password and unlock the drive at boot?
Thanks,
Adam
Adam Matan
  • 12,919
Seems that I needed to edit the /etc/crypttab file, which is the crypto equivalent to fstab, and add the following line:
# create a /dev/mapper device for the encrypted drive
home    /dev/sda2       none luks
And add the following to /etc/fstab:
# /home LUKS
/dev/mapper/home /home ext4 rw 0 0
Now I get two password prompts at boot, as needed.
Adam Matan
  • 12,919
-3
I had the same problem!! However, everything is taken care of after this command! You should try it out :-)
sudo update-initramfs -u -k all
Tim
  • 13
