I'm trying to install ia32-libs and i tried nearly all commands to install this package but always i got an error. Here is what i've tried so far;
sudo apt-get install ia32libs
orkun@ubuntu:~$ sudo apt-get install ia32libs
[sudo] password for orkun:
Reading package lists... Done
Building dependency tree
N: Ignoring file 'ferramroberto-java-quantal.list.save' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
E: Unable to locate package ia32libs
sudo apt-get install package-name:i386
orkun@ubuntu:~$ sudo apt-get install package-name:i386
E: Unable to locate package package-name
Downloading this package and trying these commands;
sudo dpkg -i «package name>
orkun@ubuntu:~/İndirilenler$ sudo dpkg -i ia32-libs_20090808ubuntu36_amd64.deb
(Reading database ... 151309 files and directories currently installed.)
Preparing to replace ia32-libs 20090808ubuntu36 (using ia32-libs_20090808ubuntu36_amd64.deb) ...
Unpacking replacement ia32-libs ...
dpkg: dependency problems prevent configuration of ia32-libs:
 ia32-libs depends on ia32-libs-multiarch; however:
  Package ia32-libs-multiarch is not installed.
dpkg: error processing ia32-libs (--install):
 dependency problems - leaving unconfigured
 ia32-libs
Orkun
  • 31
Sounds like your APT doesn't have an i386 foreign architecture. I have no idea why this happens to people...
Try:
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install ia32-libs
tumbleweed
  • 8,106
Complete novice here, so I suspect that this has not been overlooked, but it looks like you're missing a "-" in your first line of code.
I just installed "ia32-libs" on Ubuntu 12.10 x86 as above for a JDK7u9 and NetBeans IDE 7.2.1 installation (apparently there is no 64-bit bundle).
Swan
I had the same problem at first. Then I tried a few methods to solve it. The one that worked is like the following:
  1. Make sure the server you selected in the "Software Sources" is the "Main Server".
  2. Search for all packages starting with "lib32" with apt-cache search lib32.
  3. Install every package that's in the list and without any "-dbg" or "-dev" suffixes.
  4. Then you can try to install the "ia32-libs" again.
This worked for me. Hope it helps.
Huan Li
  1. Download and install https://packages.debian.org/wheezy/amd64/libc6-i386/download
    sudo apt-get -f install
  2. Then execute the following commands :
    sudo apt-get update
