-1
I cannot install ia32 libs no matter how hard I try. Here is the error I get:
Reading package lists... Done
Building dependency tree
 ia32-libs : Depends: ia32-libs-multiarch but it is not installable
When I try to install ia32-libs-multiarch i get:
Package ia32-libs-multiarch is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'ia32-libs-multiarch' has no installation candidate
I've tried many things suggested on forums. Is this not fixable or is there a certain fix I may not have already tried?
Lucio
  • 19,191
  • 32
  • 112
  • 191
Sounds like your APT doesn't have an i386 foreign architecture. I have no idea why this happens to people...
Try:
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install ia32-libs
tumbleweed
  • 8,106
