I installed CCSM to enable window previews in Unity. But when I went into extras, there was no 'window preview' option.
So I tried experimenting with other options in Compiz and now there are no borders in the dialogue boxes (close, minimize, restore buttons are not there, I had enabled some 'flat....' option in Compiz.
Later, I uninstalled Compiz and then reinstalled it. Now it says
"Failed to load session Ubuntu"
I can't even access through the guest account, I am new to Ubuntu.(please explain in detail).
All I have access to is the login screen (it still shows my custom wallpaper). Please help, I don't want to lose my stuff.
Peachy
  • 7,235
  • 40
  • 47
harsh
  • 51
I got the same problem ""Failed to load session Ubuntu"" when I was trying to login afer uninstall Compiz.
I tried to boot from USB with Live Ubuntu inside and others ways but it doensnt work.
At the end, it comes up with a simple solution.
  1. Boot your Ubuntu as normal
  2. When you see the log-in screen, try to Ctrl - Alt - F1
  3. In my case (ubuntu 12.10), a blank screen appears. dont be panic, try Ctrl - Alt - F2
  4. A login console shows up and ask you to login using your id and password.
  5. After login. Run these commands. (tested)
sudo apt-get update
sudo apt-get install unity-2d
sudo apt-get install ubuntu-desktop
sudo apt-get install compizconfig-settings-manager
sudo apt-get install compiz-plugins-extra
sudo apt-get update
I got this above list of commands from How can I remove and re-install Unity? but some doesnt work so I mentioned only good-running command in my case. I highly recommend to restart your system before try to login again.
sudo shutdown -r now
Hope it helps you to solve your problem.
Linh
Linh Lino
  • 196
Open virtual console : Ctrl+Alt+F1
sudo apt-get update
sudo apt-get install -f install
sudo dpkg-reconfigure ubuntu-desktop
sudo reboot
Then try to login, This will bring back your desktop
s.m
  • 2,287
For me it seems to have been related to having a Cinnamon desktop installed that I was playing around with. Once I removed it using Failed to load session "ubuntu" - Ubuntu 13.10 on MacBook Pro everything was fine. ( I don't have a macbook pro, it was the same on my Dell desktop).
Dennis
  • 2,513
Try booting into the LiveDVD and install Compiz. It's possible that you disable Unity. Update Unity.
Add the following PPA to your Software Sources per these instructions: ppa:unity-team/staging sudo add-apt-repository ppa:unity-team/staging
After adding, open the 'Software Updater', click ‘Check for Updates’, and proceed to install those you’re prompted to do.
This can also be achieved via the Terminal by running:
sudo apt-get update && sudo apt-get dist-upgrade
Restart your computer.
TomKat
  • 3,878
