I was fooling around in a program (I forgot what it's called) and I had just seen a thing that made it so I could have multiple desktops at once. When I decided I didn't want it anymore, I thought that I had put it on from Compiz (since Compiz had options for the multiple desktops (called Cube I think), and so I disabled everything with the name "Cube" in it.
I closed my computer and once I went to login into my account, I saw that the bar on the side had disappeared. I went to restart and once I was back at the login screen, I decided to go see if I had the same problem in the Guest account. I went in it and the bar was still there, untouched. I decided that I should uninstall Compiz because the thing that I deactivated that caused the problem was from that.
I uninstalled it and when I restarted/came back on the login screen, I entered my password to go onto my main account and I received the message: Failed to load session "ubuntu". I then tried with my Guest account, but I had the same problem on it too.
Now I'm screwed in Windows 8 and I'm wondering what I can do to fix it. I've tried something about writing something in the command box that you access by pressing Ctrl-Alt-F3 (the root terminal I believe). When it asks me my password I write and I have a problem where it tells me that I wrote the wrong password. I've tried it enough times to know that there's a problem with the program.
Braiam
  • 69,112
Press CTRL+F2 for command screen.
sudo apt-get update
sudo apt-get install unity-2d
sudo apt-get install ubuntu-desktop
sudo apt-get install compizconfig-settings-manager
sudo apt-get install compiz-plugins-extra
sudo apt-get update
Huseyin
  • 802
