tl;dr version: Additional Drivers does not work for enabling a driver in Ubuntu 12.10, however it worked in 12.04.
I upgraded to Ubuntu 12.10 from 12.04 via a live USB. I did a fresh install to avoid any conflicts. From 12.04 I know that my wireless card has proprietary drivers that could be installed via Additional Drivers. I did eventually find additional drivers in the software sources menu, however when I attempt to switch to Broadcom 802.11 Linux STA wireless driver source from bcmwl-kernel-source, it not only does not work, it in fact disables my wireless completely. The only way to revert this is to restart, and revert back to "do not use the device". Then upon another restart, my wireless will function once again. I was curious if anyone else had this issue, and if there was a fix for it as of yet. I looked on launchpad and it may be a potential bug, but I am unsure.
Any help would be greatly appreciated (and sorry for that wall of text). Until then, I'll continue to use my wireless as it is (or revert to 12.04), but I do notice a slower connection without it enabled.
jokerdino
  • 41,732
Compt
  • 468
Work for me=> check this, i hope that resolve your problem
Please run:
lspci -nn | grep 0280
Is your pci.id 14e4:4353? If so,please do:
sudo apt-get install linux-headers-generic
sudo apt-get install --reinstall bcmwl-kernel-source
sudo modprobe wl
Your wireless should now be working.
If your pci.id is different, please post it and we'll recommend a fix.
I had the same problem installing 12.04 and 12.10 on a friend's Dell netbook. I installed Linux Mint instead and managed to get it working. Installed 12.10 again this morning and had to go into Software Sources again and re-install the broadcom driver from there - although it was selected when asked on pr-install setup.
I managed to install it by installing the broadcom-sta-common first and then install that driver . Hope this help
Probably you have to:
It works perfectly for me.
More information.
neolie
