I was using ibus-avro with ibus input method to write Bengali in Ubuntu 12.04. Recently I have upgraded Ubuntu from 12.04 to 12.10, now ibus-avro was removed. I have tried to install it again but was getting error message as follows
ibus-avro : Depends: gir1.2-gjsdbus-1.0 but it is not installable
Braiam
  • 69,112
Apurba
  • 1,438
Finally I am able to install it. I have compiled it from the source without installing gir1.2-gjsdbus-1.0 and till now it is working perfectly.
First install the bellow mention packages using the code.
sudo apt-get install git ibus libibus-1.0-dev automake autoconf gjs gir1.2-ibus-1.0
Now install the following code to download, compile and install the ibus-avro
git clone git://github.com/sarim/ibus-avro.git
cd ibus-avro
aclocal && autoconf && automake --add-missing
./configure --prefix=/usr
sudo make install
I have found this instruction from in this link
https://github.com/sarim/ibus-avro/blob/master/README.md
You may notice that I have omitted the package "gir1.2-gjsdbus-1.0" which is told by Sarim in the comment of an issue, you can check it in the following link
https://github.com/sarim/ibus-avro/issues/37
Thanks
Apurba
  • 1,438
-1
I found the solution from here.... just do what it tells you to do and compile the sources as described.... http://forum.linuxdesh.org/thread-1088.html
