I noticed that the perl version (5.14) shipped with 12.10 does not include the Switch.pm module needed while building WebKiT-GTK.
Looking around on the internet I found few suggestions indicating that I should install something call p5-switch from ports. I have looked around and was not able to get this done. I am not a perl guy and have no idea where i can get this package.
Can someone please help me as to
  1. Where to download the package for ubuntu 12.10
  2. In case it is not a .deb, How do i install it.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
If you want to install the Switch.pm Perl module into your system Perl config, there are two methods of installing it:
  1. Install it through the Ubuntu repositories.
  2. Install the .pm through CPAN.
At this time, both will provide the current version of this module(2.16).
Installing Switch.pm using the Ubuntu repositories:
  • From the command-line, the installation can be completed by running the following command from the terminal (Ctrl-Alt-t):
    sudo apt-get install libswitch-perl
    • Within Synaptic, right-click on the libswitch-perl package, select Mark for installation, then click on the Apply button.
    • Within the Ubuntu Software Center (USC), search for the phrase libswitch-perl, highlight the package and select install:
Installing Switch.pm using CPAN: If you would prefer to install this via cpan, follow these instructions:
  1. Open a terminal(Ctrl-Alt-t).
  2. Enter the command cpan.
  3. At the prompt cpan[1]>, type install Switch.
  4. Once completed, Type exit.
The Switch.pm Perl module will now be available for you to use in your scripts.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
