There are other threads related to this question for Ubuntu 12.04, however THEY DO NOT APPLY TO 12.10. This is not a duplicate of another thread if the referenced thread doesn't answer the question asked.
For the purpose of this question: Catalyst = fglrx = proprietary AMD/ATI display driver
The most problems people are having come from the fact that:
1. Ubuntu has moved to newer driver versions, that don't support some older ATI/AMD chips
2. Ubuntu has moved to newer Xorg versions
Symptoms:
No. 1 - 'not supported' errors / Jockey not detecting proprietary drivers valid for installation
No. 2 - some older ATI/AMD Catalyst versions won't install
Which all comes down to:
Your chip is no longer supported by the latest ATI/AMD catalyst display drivers (be it via manual install or from Ubuntu repositories)
Solution:
Check, what is the latest driver version that supports your chip and then proceed with the installation accordingly.
http://wiki.cchtml.com/index.php/Hardware (may be slightly outdated)
or
enter your graphic card details here:
http://support.amd.com/us/gpudownload/Pages/index.aspx
use terminal command to display information about your graphics
lspci | grep VGA
If the latest version for you is 12.6 => proceed as per https://askubuntu.com/a/201785/29347
Chips that are indicated 'legacy' (not supported for the latest Catalyst versions):
Try the PPA listed here How to install old AMD Catalyst 12.4 drivers on Ubuntu 12.10?
You'll most probably get Catalyst 12.6
Chips that ARE supported in 12.10 / by the latest Catalyst drivers:
The installation should be accomplished as per What is the correct way to install proprietary ATI Catalyst Video Drivers (fglrx) directly from AMD?
The latest ATI catalyst for Ubuntu 12.10 I know of is this one:
AMD Catalyst 12,9 driver
First Uninstall the current driver AMD with these commands:
sudo sh /usr/share/ati/fglrx-uninstall.sh
sudo apt-get remove --purge fglrx fglrx_* fglrx-amdcccle* fglrx-dev* xorg-driver-fglrx
Manual installation:
To install AMD Catalyst 12.9 in Ubuntu 12.10/12.04/11.10 run the following commands from the terminal:
sudo apt-get install unzip
cd /tmp && wget -O amd-12.9-9.00-EDG_Direct.zip http://www2.ati.com/drivers/embedded/9.00-120815a-146426C-EDG_Direct.zip
unzip amd-12.9-9.00-EDG_Direct.zip
chmod +x amd-driver-installer-9.00-x86.x86_64.run
sudo sh amd-driver-installer-9.00-x86.x86_64.run
And then after the installation was finished run this command:
sudo aticonfig --initial -f
Then reboot.
Note: PPA has not been updated so far, but the driver will be updated soon. To install the driver provided by xorg-edgers, open the terminal and run the following commands:
sudo add-apt-repository ppa:xorg-edgers/ppa
sudo apt-get update
sudo apt-get install fglrx-installer
- 373
Here is the latest version of Ati Catalyst 12.11 (beta) and 12.10 (stable) that has just been released ,you can find it here : http://www.upubuntu.com/search/label/System hope it will work .
- 373
If you would like to update your ATI / AMD Catalyst Proprietary Display Drivers to the latest release, or would like to try the latest AMD Catalyst BETA drivers, have look at :
The Fan Club - Ubuntu AMD Catalyst install
- The application auto detects your ATI / AMD graphics hardware and selects the best driver options to install.
- This application downloads, creates DEB packages and installs the latest AMD Catalystâ„¢ Proprietary Display Drivers for Ubuntu 32bit/64bit.
- You can also install the latest AMD Catalystâ„¢ Proprietary Display BETA Drivers as well as Legacy AMD Catalystâ„¢ Proprietary Display Drivers if your hardware is supported.
- 350
