I used to dual boot Ubuntu with Windows 7. I got rid of Windows and also deleted the partition where it was installed.
Now, in the dual boot menu Windows 7 is still available, and listed as first option. How do i completely remove the menu so that Ubuntu boots directly? Thanks in advance.
Mokus
  • 4,592
Open the terminal application and enter
sudo update-grub
This probes for other existing OSes and writes a new grub configuration; since you deleted the windows partition, it shouldn't be in the menu anymore on the next boot.
You can also disable the Grub Os Prober if you like. Just add GRUB_DISABLE_OS_PROBER=true to /etc/default/grub and run sudo update-grub again.
To disable the display of the menu:
Edit /etc/default/grub with elevated rights
and set GRUB_TIMEOUT=0
Run sudo update-grub again.
phoibos
  • 22,176
You can use an easy to use GUI app called grub-customizer to make your life a little easy. As the name suggests, you can do much more than just reordering Grub menu entries with it.
You can install it by:
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt-get update
sudo apt-get install grub-customizer
More information in the following page: How do I change the GRUB boot order?
Mokus
  • 4,592
