Possible Duplicate:
How to automount NTFS partitions?
I now this question has been asked a million times but this is a bit different, now I need to know on how to mount it on ubuntu 12.10 I been using PYSDM for a long time but on ubuntu 12.10 it does not work sadly, I installed arios-automount and it mounted partitions on start up but problem i have with it, on start up it launches all the partition window
So can anyone tell me a good mount manager for ubuntu 12.10 with graphical user interface
thank you for your time
Levan
  • 11,118
You can edit the /etc/fstab file to mount partitions at boot time. That's the traditional method.
Use Alt-Ctrl-T to start a terminal. Create a mount point with sudo mkdir /media/ntfs. then use gksudo gedit /etc/fstab and enter a line for the mount you want.
Here's one for my ntfs partition:
UUID=CA009B90009B825D /media/ntfs ntfs rw,nosuid,nodev,noatime,allow_other 0 0
You will have to specify your own UUID. You can find these by entering the command:
sudo blkid
John S Gruber
  • 13,436
