Possible Duplicate:
Grub rescue - error: unknown filesystem
My computer has (had) a dual boot of Ubuntu Precise and Windows 7. Recently, when I started the computer, grub gave me an error saying "Unknown filesystem", and sent me to grub rescue. I searched for solutions to this, and found this answer: Unknown filesystem error: grub rescue. I followed the instructions there, but they didn't really help: when I restarted the computer, it went straight to Windows without grub intervening at all (so it boots successfully, just not to the OS I want). This is the log from boot-repair. My Ubuntu partition is sda6.
Naturally, I'm a little worried, since the log says "unknown filesystem type ''", which to me looks like the partition might be corrupt somehow. From the Ubuntu Live CD, I started gparted and looked at my partitions, and it also told me that my sda6 is an unknown filesystem.
So my questions are basically:
  1. Can I restore Ubuntu to the way it was?
  2. If not, can I at least rescue the data I had on the partition somehow?
  3. Again, if I can't restore Ubuntu, how do I clean everything up so that I can reinstall it without too many complications?
Another thing I should mention is that yesterday I had a similar problem where the computer told me there was a problem with the hard drive when it was starting, but it fixed itself by running fsck (that time it got past grub, and managed to start Ubuntu). Between that occasion and me having trouble booting the computer today, I have booted it successfully at least twice.
Thanks for any help!
EDIT: Since I got the popular question badge for this, I might as well add for anyone looking that the computer's hard drive was just broken and I had to replace it. I guess it was unsalvageable.
Ben FL
  • 113
I saw the boot-info you provided.
This is an attempt to fix the corrupted filesystem
Possible data loss!!
You can apply this Only when you haven't any other options to rescue your data or to fix the problem
Boot from a LiveCD/Usb of Ubuntu. Open a terminal and do
sudo mke2fs -n /dev/sda6
The /dev/sda6 partition is the partition where Ubuntu was installed and now is corrupted.
Above command will provide you with a list of Superblock backups stored on blocks
Take one number from there (usually the first one) and then apply bellow command
sudo e2fsck -y -b block_location /dev/sda6
Where block_location replace it with the (first) number from the results of Superblock backups stored on blocks
When this finish , run the boot-repair program and select the [Recommended Repair] option.
If everything else fails
As a last resort you can re-install Ubuntu without format the partition. After all is about what ? 10-15 minutes. Boot from LiveCD-Usb and select install. Then at the installer window click on "something else" and then take a look at these two pictures and you will figure out what you must do.
installation
installation2
NickTux
  • 17,865
  • 57
  • 66
