I've been following the instructions on this page to copy my Linux partition from one partition to another on the same drive. (I'm doing this because I want to move it from /dev/sda3 to /dev/sda4 so that I can then resize /dev/sda2 and use my drive more efficiently).
I got up to "1. Reboot you machine again" under Step 6, but 'UBUNTU' on the copied partition never appears in the grub boot menu. I only ever see my original /dev/sda3 version. I have tried reinstalling GRUB and it says it's been successful, but there's no change.
Are those instructions wrong? Is there just something wierd with my computer? Can you suggest how to get this working?
thornate
  • 123
After a bit of fiddling, I worked this one out myself. I needed to repair GRUB using the instructions here.
Quick precis of the steps:
Boot in to live CD. Mount the new partition to /mnt:
sudo mount /dev/sda2 /mnt  # make sure that sda2 is correct!
Bind the various local directories so that chroot will work:
for i in /sys /proc /run /dev; do sudo mount --bind "$i" "/mnt$i"; done
chroot in to the new partition:
sudo chroot /mnt
At which point you're running Ubuntu in the new partition. Then from there, update and reinstall GRUB:
update-grub
grub-install /dev/sda
You might need to update GRUB again afterwards.
Then reboot and the GRUB menu will be updated.
At that point I booted in to the new partition, deleted the old one, and updated GRUB to reflect that change.
thornate
  • 123
Boot into the live CD and then do this in the terminal
sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt-get update
Let it do its thing, and then do this
sudo apt-get install -y boot-repair && boot-repair
follow the defaults "Fix most common problems" or whatnot If it breaks again, come back.
TardisGuy
  • 367
