I have a Vostro 2520 and not sure how to enable wireless on my machine. The details are given below, would appreciate any pointers to resolving this issue.
lsmod returns
Module                  Size  Used by ath9k                 132390  0
ath9k_common           14053  1 ath9k ath9k_hw              411151  2
ath9k,ath9k_common ath                    24067  3
ath9k,ath9k_common,ath9k_hw b43                   365785  0  mac80211
506816  2 ath9k,b43 cfg80211              205544  4
ath9k,ath,b43,mac80211 bcma                   26696  1 b43 ssb
52752  1 b43 ndiswrapper           282628  0  ums_realtek
18248  0  usb_storage            49198  1 ums_realtek uas
18180  0  snd_hda_codec_hdmi     32474  1  snd_hda_codec_cirrus
24002  1  joydev                 17693  0  parport_pc
32866  0  ppdev                  17113  0  rfcomm
47604  0  bnep                   18281  2  bluetooth
180104  10 rfcomm,bnep psmouse                97362  0  dell_wmi
12681  0  sparse_keymap          13890  1 dell_wmi snd_hda_intel
33773  3  snd_hda_codec         127706  3
snd_hda_codec_hdmi,snd_hda_codec_cirrus,snd_hda_intel snd_hwdep
13668  1 snd_hda_codec snd_pcm                97188  3
snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec snd_seq_midi
13324  0  snd_rawmidi            30748  1 snd_seq_midi
snd_seq_midi_event     14899  1 snd_seq_midi snd_seq
61896  2 snd_seq_midi,snd_seq_midi_event snd_timer              29990
2 snd_pcm,snd_seq snd_seq_device         14540  3
snd_seq_midi,snd_rawmidi,snd_seq wmi                    19256  1
dell_wmi snd                    78855  16
snd_hda_codec_hdmi,snd_hda_codec_cirrus,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
mac_hid                13253  0  i915                  473240  3
drm_kms_helper         46978  1 i915 uvcvideo               72627  0
drm                   242038  4 i915,drm_kms_helper videodev
98259  1 uvcvideo soundcore              15091  1 snd dell_laptop
18119  0  dcdbas                 14490  1 dell_laptop i2c_algo_bit
13423  1 i915 v4l2_compat_ioctl32    17128  1 videodev snd_page_alloc
18529  2 snd_hda_intel,snd_pcm video                  19596  1 i915
serio_raw              13211  0  mei                    41616  0  lp
17799  0  parport                46562  3 parport_pc,ppdev,lp r8169
62099  0
sudo lshw -class network
  *-network UNCLAIMED
       description: Network controller
       product: Broadcom Corporation
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:07:00.0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: latency=0
       resources: memory:f7c00000-f7c07fff   *-network
       description: Ethernet interface
       product: RTL8111/8168B PCI Express Gigabit Ethernet controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:09:00.0
       logical name: eth0
       version: 07
       serial: 78:45:c4:a3:aa:65
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd
autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168e-3_0.0.4
03/27/12 ip=192.168.1.5 latency=0 link=yes multicast=yes port=MII
speed=100Mbit/s
       resources: irq:41 ioport:e000(size=256) memory:f0004000-f0004fff memory:f0000000-f0003fff
rfkill list all
0: dell-wifi: Wireless LAN  Soft blocked: yes   Hard blocked: yes 1:
dell-bluetooth: Bluetooth   Soft blocked: yes   Hard blocked: yes
Output of lspci:
00:00.0 Host bridge: Intel Corporation Ivy Bridge DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Ivy Bridge Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation Panther Point MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation Panther Point USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation Panther Point High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 1 (rev c4)
00:1c.3 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 4 (rev c4)
00:1c.5 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 6 (rev c4)
00:1d.0 USB controller: Intel Corporation Panther Point USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation Panther Point LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation Panther Point 6 port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation Panther Point SMBus Controller (rev 04)
07:00.0 Network controller: Broadcom Corporation Device 4365 (rev 01)
09:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 07)
Output of lspci -v:
    Subsystem: Dell Device 0558
    Flags: bus master, fast devsel, latency 0
    Capabilities: <access denied>
    Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller: Intel Corporation Ivy Bridge Graphics Controller (rev 09) (prog-if 00 [VGA controller])
    Flags: bus master, fast devsel, latency 0, IRQ 43
    Memory at f7800000 (64-bit, non-prefetchable) [size=4M]
    Memory at e0000000 (64-bit, prefetchable) [size=256M]
    I/O ports at f000 [size=64]
    Expansion ROM at <unassigned> [disabled]
    Kernel driver in use: i915
    Kernel modules: i915
    Flags: bus master, fast devsel, latency 0, IRQ 42
    Memory at f7d0a000 (64-bit, non-prefetchable) [size=16]
    Kernel driver in use: mei
    Kernel modules: mei
00:1a.0 USB controller: Intel Corporation Panther Point USB Enhanced Host Controller #2 (rev 04) (prog-if 20 [EHCI])
    Flags: bus master, medium devsel, latency 0, IRQ 16
    Memory at f7d08000 (32-bit, non-prefetchable) [size=1K]
    Kernel driver in use: ehci_hcd
    Flags: bus master, fast devsel, latency 0, IRQ 44
    Memory at f7d00000 (64-bit, non-prefetchable) [size=16K]
    Kernel driver in use: snd_hda_intel
    Kernel modules: snd-hda-intel
00:1c.0 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 1 (rev c4) (prog-if 00 [Normal decode])
    Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
    Kernel driver in use: pcieport
    Kernel modules: shpchp
00:1c.3 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 4 (rev c4) (prog-if 00 [Normal decode])
    Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
    Memory behind bridge: f7c00000-f7cfffff
00:1c.5 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 6 (rev c4) (prog-if 00 [Normal decode])
    Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
    I/O behind bridge: 0000e000-0000efff
    Prefetchable memory behind bridge: 00000000f0000000-00000000f00fffff
00:1d.0 USB controller: Intel Corporation Panther Point USB Enhanced Host Controller #1 (rev 04) (prog-if 20 [EHCI])
    Flags: bus master, medium devsel, latency 0, IRQ 23
    Memory at f7d07000 (32-bit, non-prefetchable) [size=1K]
    Kernel modules: iTCO_wdt
00:1f.2 SATA controller: Intel Corporation Panther Point 6 port SATA Controller [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
    Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 40
    I/O ports at f0b0 [size=8]
    I/O ports at f0a0 [size=4]
    I/O ports at f090 [size=8]
    I/O ports at f080 [size=4]
    I/O ports at f060 [size=32]
    Memory at f7d06000 (32-bit, non-prefetchable) [size=2K]
    Kernel driver in use: ahci
    Flags: medium devsel, IRQ 11
    Memory at f7d05000 (64-bit, non-prefetchable) [size=256]
    I/O ports at f040 [size=32]
    Kernel modules: i2c-i801
    Subsystem: Dell Device 0016
    Flags: bus master, fast devsel, latency 0, IRQ 10
    Memory at f7c00000 (64-bit, non-prefetchable) [size=32K]
    Flags: bus master, fast devsel, latency 0, IRQ 41
    I/O ports at e000 [size=256]
    Memory at f0004000 (64-bit, prefetchable) [size=4K]
    Memory at f0000000 (64-bit, prefetchable) [size=16K]
    Kernel driver in use: r8169
    Kernel modules: r8169
Eric Carvalho
  • 55,453
Joe
  • 417
Edit the file /etc/modprobe.d/blacklist.conf and in the end type :
blacklist acer_wmi
Reboot and you’re done. If you’re doing it entirely from the GUI, then editing the file could be done by pressing ALT+F2 (this would open a “Run” window) and typing there gksu gedit /etc/modprobe.d/blacklist.conf then add this line below
rmmod dell_laptop
penreturns
  • 5,950
Try this:
sudo apt-get install firmware-b43-installer
sudo apt-get remove bcmwl-kernel-source
It worked for me on a Dell Inspiron 6400 with the Broadcom wifi chip.
To Do
  • 15,833
Open terminal. Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command below.
sudo rfkill unblock all
Mitch
  • 109,787
Moheet
