47
What is the terminal command that can used to find the bitrate of an mp3 file?
Is there any other option available other than mpg321 -t name.mp3?
devav2
  • 37,290
5 Answers5
53
MediaInfo is further solution to do that (not only on mp3).
sudo apt-get install mediainfo
Example:
mediainfo Aphrodite_-_Superman_\(dnb\).mp3 | grep "Bit rate"
Output:
Bit rate mode                            : Constant
Bit rate                                 : 192 Kbps
Another Example:
mediainfo Aphrodite_-_Superman_\(dnb\).mp3 | grep 'Bit rate  '
Another Output:
Bit rate                                 : 192 Kbps
Get exactly the audio bitrate via mediainfo in bps:
mediainfo --Output='Audio;%BitRate%' '/MY/MEDIA/FILE.MP3'
or in Kbps:
mediainfo --Output='Audio;%BitRate/String%' '/MY/MEDIA/FILE.MP3'
muru
  • 207,228
BuZZ-dEE
  • 14,533
47
Simply put:
file song.mp3
Note: file is included with Ubuntu.
For alias lovers, insert this at the end of your ~/.bashrc file:
bitrate () {
    echo `basename "$1"`: `file "$1" | sed 's/.*, \(.*\)kbps.*/\1/' | tr -d " " ` kbps
Open a new Terminal window. You may now run the following command:
bitrate song.mp3
SirCharlo
  • 40,096
28
Install mp3info package
sudo apt-get install mp3info
To find the bitrate use
mp3info -r a -p "%f %r\n" *.mp3
will give the info you need, also has some other useful functions man mp3info for more info
devav2
  • 37,290
apacheuk
  • 948
12
You can install the package libimage-exiftool-perl:
sudo apt-get install libimage-exiftool-perl
Then run:
exiftool -AudioBitrate GoldLion.mp3
It will output something like:
Audio Bitrate : 192 kbps
SirCharlo
  • 40,096
carey
  • 151
The best info, by-far, is provided by ffprobe (part of the ffmpeg package). mpg123 is also nice, but hard to grep output, which is probably why you were asking for something else.
$ mpg123 -t example.mp3 2>&1 | grep -A1 -E "^MPEG"
MPEG 2.5 L III cbr32 11025 mono
$ ffprobe example.mp3 2>&1 | grep Stream
    Stream #0:0: Audio: mp3, 11025 Hz, mono, s16p, 32 kb/s
For pro-use, do this:
# ffprobe -v quiet -print_format json -show_format -show_streams example.mp3
    "streams": [
            "index": 0,
            "codec_name": "mp3",
            "codec_long_name": "MP3 (MPEG audio layer 3)",
            "codec_type": "audio",
            "codec_time_base": "1/11025",
            "codec_tag_string": "[0][0][0][0]",
            "codec_tag": "0x0000",
            "sample_fmt": "s16p",
            "sample_rate": "11025",
            "channels": 1,
            "channel_layout": "mono",
            "bits_per_sample": 0,
            "r_frame_rate": "0/0",
            "avg_frame_rate": "0/0",
            "time_base": "1/14112000",
            "start_pts": 0,
            "start_time": "0.000000",
            "duration_ts": 55294344,
            "duration": "3.918250",
            "bit_rate": "32000",
            "disposition": {
                "default": 0,
                "dub": 0,
                "original": 0,
                "comment": 0,
                "lyrics": 0,
                "karaoke": 0,
                "forced": 0,
                "hearing_impaired": 0,
                "visual_impaired": 0,
                "clean_effects": 0,
                "attached_pic": 0,
                "timed_thumbnails": 0
    "format": {
        "filename": "example.mp3",
        "nb_streams": 1,
        "nb_programs": 0,
        "format_name": "mp3",
        "format_long_name": "MP2/3 (MPEG audio layer 2/3)",
        "size": "17260",
        "bit_rate": "35240",
        "probe_score": 51,
        "tags": {
            "title": "Sound Effects - Female Operatic La 1 - Opera singer sings La.",
            "artist": "Download Sound Effects - SoundDogs - AOS",
            "album": "http://www.Sounddogs.com",
            "track": "0",
            "copyright": "(c) 2010 Sounddogs.com, All Rights Reserved",
            "genre": "SFX - Humans; Vocalizations",
            "comment": "Royalty Free Sound Effects - Sounddogs.com",
            "date": "2008"
not2qubit
  • 616
