Possible Duplicate:
How do I modify or disable the HUD's use of the Alt key?
I frequently work with Emacs in the GNOME terminal on Ubuntu 12.04. I have a pretty vanilla setup at the moment and I keeping running into this one problem that I haven't been able to resolve.
When using Emacs I frequently use ALT(meta) and probably one out of every ten times I use it my timing is off by just enough that Ubuntu/Unity interprets my ALT as a call for the terminal menu popping up on the HUD. This is frustrating because I am usually typing at such a rapid pace that a ton of my commands get put into the HUD search instead of into the terminal which throws off my work flow. So my question is:
Is there a way to disable the Unity HUD for certain applications or change the way it interprets ALT?
Any approach for solving this problem would be appreciated. Thanks!
Zanna
  • 72,312
Jared
