I have an Intenso 6002560 1TB Memory Station - an external hard disk. This hard disk gets connected via Y-USB cable. When I connect both USB-ends to my Notebook, it gets recognized by my Ubuntu 10.04.4 LTS system:
moose@pc07:~$ lsusb
Bus 002 Device 005: ID 13fd:1840 Initio Corporation
and
Disk /dev/sda: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00065e10
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *           1       37810   303704064   83  Linux
/dev/sda2           37810       38914     8864769    5  Extended
/dev/sda5           37810       38914     8864768   82  Linux swap / Solaris
Disk /dev/sdc: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders
Disk identifier: 0x0d6ea32a
/dev/sdc1               1      121601   976759008+   c  W95 FAT32 (LBA)
But it did not get mounted:
moose@pc07:/dev$ mount -l
/dev/sda1 on / type ext4 (rw,errors=remount-ro,user_xattr)
proc on /proc type proc (rw,noexec,nosuid,nodev)
none on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
none on /dev type devtmpfs (rw,mode=0755)
none on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
none on /dev/shm type tmpfs (rw,nosuid,nodev)
none on /var/run type tmpfs (rw,nosuid,mode=0755)
none on /var/lock type tmpfs (rw,noexec,nosuid,nodev)
none on /lib/init/rw type tmpfs (rw,nosuid,mode=0755)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,noexec,nosuid,nodev)
gvfs-fuse-daemon on /home/moose/.gvfs type fuse.gvfs-fuse-daemon (rw,nosuid,nodev,user=moose)
However, I could mount it manually with
mount -t vfat /dev/sdc1 /mnt/sdc1
as you can see here:
moose@pc07:~$ mount -l
/dev/sdc1 on /mnt/sdc1 type vfat (rw)
edit: Another command:
moose@pc07:~$ sudo blkid -o list
device                     fs_type    label       mount point                    UUID
/dev/sda1                  ext4                   /                              45eb611b-517e-425b-8057-0391726cccd5
/dev/sda5                  swap                   <swap>                         e9dc42f3-594c-4b62-874a-305eda5eed41
moose@pc07:~$ blkid -o list
/dev/sdc1                                         /mnt/sdc1
edit: another command:
moose@pc07:~$ ls -l /dev/disk/by-uuid/
total 0
lrwxrwxrwx 1 root root 10 2012-09-30 09:31 45eb611b-517e-425b-8057-0391726cccd5 -> ../../sda1
lrwxrwxrwx 1 root root 10 2012-09-30 09:31 e9dc42f3-594c-4b62-874a-305eda5eed41 -> ../../sda5
Here is a link to a Launchpad question about this problem.
But I would like it to mount automatically. What do I have to do?
Martin Thoma
  • 20,535
It's an old question but I figured this might still help someone.
I've had the same problem with this hdd. The source turned out to be the initial format of the partition. Reformatting as NTFS using the Disks (gnome-disks) tool made it behave like any other usb hdd.
user2361830
  • 136
Here you have a good guide on how to mounting drives.
https://help.ubuntu.com/community/AutomaticallyMountPartitions
You should add your drive to the /etc/fstab file which controls the mounted devices, with parameters such as
  • the mounting drive,
  • the mounting point
  • used filesystem
  • and several other options
good luck!
EDIT: If you modify fstab manually instead of using some interface, be careful with the lines you change. Do a backup of the file first or you could make your system to not boot properly.
luso
  • 211
Since it is mounted, run sudo blkid so you see the UUID of the volume. Then, in /etc/fstab, add:
UUID=xxx /media/xxx vfat 0 0
bob
  • 1,198
