Possible Duplicate:
How do I open Deja Dup as root?
I am using Ubuntu 12.04 LTS. I'm trying to setup Deja Dup to backup the files for several users (/home) and /etc but as it runs as myself, there are many files it cannot read and therefore cannot backup.
I want to try running Deja Dup as root as then it should be able to read and backup all files.
I've seen some other info about how to set up a particular App to run as root, so I guess I should try that.
To Enable root login, open Terminal and enter following commands:
sudo passwd root
sudo sh -c 'echo "greeter-show-manual-login=true" >> /etc/lightdm/lightdm.conf'
Now Restart your lightdm and login as root.
sudo service lightdm restart
Once you've unlocked the root account, you have to edit /etc/lightdm/users.conf and change minimum-uid to 0.
Sly
  • 762
