I want to completely remove Unity-2D (not Unity) on Ubuntu Precise Pangolin 12.04. I used dpkg -l | grep unity-2d to list the packages which belongs to Unity-2D. The result was this:
 ii  libunity-2d-private0    5.12.0-0ubuntu1.1    Unity 2D shared library
 ii  unity-2d                5.12.0-0ubuntu1.1    Unity interface for non-accelerated graphics cards
 ii  unity-2d-common         5.12.0-0ubuntu1.1    Unity 2D Panel
 ii  unity-2d-shell          5.12.0-0ubuntu1.1    Dash and Launcher for the Unity 2D environment
 ii  unity-2d-spread         5.12.0-0ubuntu1.1    Unity 2D Spread
Now I want to remove those packages with:
 sudo apt-get purge unity-2d unity-2d-common unity-2d-panel unity-2d-shell unity-2d-spread libunity-2d-private0
Then I get a the following message:
The following packages will be REMOVED:
  libunity-2d-private0* ubuntu-desktop* unity-2d* unity-2d-common* unity-2d-panel* unity-2d-shell* unity-2d-spread*
which means that the package ubuntu-desktop should also removed. But the decription from that package apt-cache show ubuntu-desktop says:
Description-en: The Ubuntu desktop system
 This package depends on all of the packages in the Ubuntu desktop system
 It is also used to help ensure proper upgrades, so it is recommended that
 it not be removed.
that it should not be removed, because it is needed to ensure a successful system-update.
How can I remove Unity-2D without removing Ubuntu-Desktop?
BuZZ-dEE
  • 14,533
It is perfectly okay to remove ubuntu-desktop package if you want to remove Unity and Unity-2D. Because ubuntu-desktop is a meta package and used to pull the standard packages in an Ubuntu Desktop installation. Since you are removing a dependency of Ubuntu-Desktop package, it will be removed too.
But, you don't need to worry. You won't lose anything by removing it. You might take a look at this question.
For the specific query:
You just cannot. There is no way to have Ubuntu-Desktop package with Unity-2D removed without being please with a broken package system.
Anwar
  • 77,855
-1
Remove or modify the file /usr/share/xsessions/ubuntu-2d.desktop. For example, do
sudo mv /usr/share/xsessions/ubuntu-2d.desktop /root/ubuntu-2d.desktop.backup
Unfortunately, you cannot selectively remove the 2D libraries from the system without breaking the dependencies, because the authors of Ubuntu decided that 2D is mandatory for Ubuntu.
EDIT: If you want to remove Unity-2D (but only Unity-2D, not anything else), there are two strategies:
  1. Go with loosing Unity-Desktop. This will not remove the other unity libraries, as Unity-Desktop is just a meta-package, it's purpose is to depend on a large number of other packages such that by installing this single package, you also install all these dependencies.
  2. (much, much harder) Create a dummy meta-package that provides the Unity-2D package, but does not install any files.
BuZZ-dEE
  • 14,533
January
  • 37,208
