Possible Duplicate:
My computer boots to a black screen, what options do I have to fix it?
I installed Lucid Lynx over PXE onto this dell server seemingly successfully, but booting from the HD results in a black, unpowered screen. There appears to be no network connectivity to the box either. It may have landed at a textual busybox type prompt, but I can't see it. Ctrl-Alt-Delete seems to reboot.
On my last attempt I held shift and the grub menu came up, but recovery mode produced the same results.
Should I drop into the grub prompt and give the kernel a magical boot option? Should I boot from a rescue cd and munge some bits on the HD? Give up and install windows?
Ron
  • 183
Here are a couple of "magical boot options" to try:
  • nomodeset
  • i915.modeset=0 xforcevesa
I'd remove quiet splash when trying these and only one at a time, not together as they'll likely conflict.
Edit: for an explanation of how to use these:
  • When booting, hold left-Shift
  • Highlight the first option and press e
  • Go down to the line that looks like:
    /boot/vmlinuz-3.0.blah-generic root=UUID=blah ro quiet splash
  • Replace quite splash with your boot option of choice.
If that works out well, you can make the changes to /etc/default/grub by editing the GRUB_CMDLINE_LINUX_DEFAULT value. After saving, run sudo update-grub.
Oli
  • 299,380
It is likely to be related to plymouth/mountall check the following blog entry for some tips: http://handypenguin.blogspot.com/2010/04/when-recovery-mode-fails-to-boot.html
João Pinto
  • 17,323
