Possible Duplicate:
Sharing files in LAN through Samba or SSH
I would to know how can I transfer data using LAN from an Ubuntu machine to another! I am using a wireless router, obviously, I can see mine in the windows network but I guess I must do something else. Thank you
Jeff Labonte
  • 271
  • 19
Install a file sharing server such as SAMBA. Then you can make a shared folder between your windows and Ubuntu hosts. You can download samba from here Or you can do it via synaptic or Ubuntu Software center or via command line
sudo apt-get install samba
You can use Transfer on LAN. It needs Java 6 then it works on Ubuntu, Windows, Mac. It is easy to use because no configuration is required.
Arno
