The title says it all. It's a bit of an eyesore with propriety NVIDIA drivers, so I tried here. I'm pretty sure I reversed all settings, when it did not work for me. But now:
sudo update-alternatives --config default.plymouth
Returns error:
update-alternatives: error: cannot stat file '/lib/plymouth/themes/default.plymouth': Too many levels of symbolic links
I just wanna revert back to the vanilla 12.04 LTS Plymouth splash. Thanks. Also:
sudo gedit /lib/plymouth/themes/default.plymouth
Returns:
"The number of followed links is limited and the actual file could not be found within this limit."
EDIT: Should I restore from image backup (I see this filed as bug on Launchpad.) Or is there a fix?
fleamour
  • 1,583
Sounds like your default.plymouth alternatives links are broken.
cd /lib/plymouth/themes
ls -l default.plymouth
Should give you
lrwxrwxrwx 1 root root 34 Oct 25  2011 default.plymouth -> /etc/alternatives/default.plymouth
And
cd /etc/alternatives
Should give you a link pointing to a .plymouth file in the /lib/plymouth/themes directory. E.g. For the default splash this should be pointing at: /lib/plymouth/themes/ubuntu-logo/ubuntu-logo.plymouth
If not fix the links. You should then be able to configure plymouth in the normal way.
Matt Caswell
  • 2,340
Follow these steps:
Step 1:
Type into the terminal (Ctrl-Alt-T)
Step 2:
Choose the number associated with the default plymouth in the options that pop up.
Step 3
Type in the terminal
sudo update-initramfs –u
Then
sudo reboot
Also have a look at this Q&A if you want an alternative Plymouth that works
stephenmyall
  • 9,885
