26
I have installed Nemo (a fork of Nautilus created by the Linux Mint Team) in my Ubuntu 12.04.1 LTS with Gnome Shell 3.4.2. I followed the instructions DefaultFileManager on help.ubuntu.com, changing the "inode" and "x-directory" in the file "defaults.list", to make Nemo my default file manager.
Now everything works perfectly, except for one thing: opening folders from desktop.
I have set the option "Have file manager handle the desktop" on. Cool. The problem is that the desktop seems to be handled by Nautilus only, even if I have set another file manager as default. Every time I double click a folder on the desktop, it is opened by Nautilus, not Nemo.
Does anybody know how to fix this?
guntbert
  • 13,475
brunces
  • 659
  • 17
6 Answers6
14
Found a solution here: http://www.fandigital.com/2013/01/set-nemo-default-file-manager-ubuntu.html
The following command once typed into a terminal window (Ctrl+Alt+T) makes nemo default
xdg-mime default nemo.desktop inode/directory application/x-gnome-saved-search
How to install Nemo without Cinnamon is answered here: How do I install Nemo file manager?
daschuer
  • 139
Taken from this page:
Open up Terminal, and run the following commands (one-by-one):
sudo add-apt-repository ppa:gwendal-lebihan-dev/cinnamon-nightly
sudo apt-get update
sudo apt-get install nemo nemo-fileroller
Note the following:
Installing Nemo will also install latest Cinnamon (currently Cinnamon 1.6) into your Ubuntu installation, but it won't replace your default Ubuntu session; it just add a new entry in login session list). Be aware that Nemo is still unstable.
As of now, most GTK themes available are not designed specifically for Nemo, so Nemo won't look good when using those themes.
Also, problems with the desktop may arise: How to completely integrate Nemo with Ubuntu?
BTW: You could have probably found an answers yourself here on AU or by googling.
Mateng
  • 556
Nemo 1.7.2 is now available in the official repositories through Ubuntu Software Center, and this installation method doesn't install Cinnamon. I've installed Nemo thusly, and then used the xdg-mime command, with very satisfactory results -- removable media are now automatically opened in Nemo not Nautilus, with Tree View (which is what I wanted).
ADDED: While tinkering with the system when something is not broken is probably not recommended, for the curious, here is additional information on the creation and structure of Unity launchers that are involved in application integration with the Unity desktop.
https://help.ubuntu.com/community/UnityLaunchersAndDesktopFiles
Proceed only with extreme caution.
After installing Nemo from the Cinnamon-PPA + setting it as default file manager with:
..you still would like to disable nautilus handling the desktop and instead use nemo.
To disable natuilus, do
gsettings set org.gnome.desktop.background show-desktop-icons false
But then I'm not sure how to make Nemo handle it instead.
Konstigt
  • 370
Nemo is set to handle the desktop by default but Nautilus overrides that so Add Nemo to the mime defaults and disable Nautilus
Also if you have nautilus and nemo both running then saves from applications like Libreoffice will take a long time. solution is to make nemo the default file manager and purge nautilus. Unfortunately sometimes upgrades will re-install nautilus and make it the default manager, then you have the same slow save problem until you again purge one or the other. I like nemo as it has by default "open as root". This is very useful as no matter what sort of user you are with Linux you will end up needing to have root privileges for many files.
Ray
